Author Topic: Maintence Parts for 65' SL 230.  (Read 3767 times)
MUR44Y
« on: June 05, 2009, 10:31:34 »
Good Day,
I recently purchased a 1965 - 230 SL Manual. Looking to enjoy for the summer and begin and overhaul in the winter months.
WOuld like to give the car a service and struggling to buy the basics as not sure where to look... Was thinking I would buy plugs and points, oil, air and fuel filters to get me started - any advice would be appreciated if I need anything else?
I am based in Scotland, UK but presume can order from anywhere...
Thanks in advance,
Ian
Re: Maintence Parts for 65' SL 230.
« Reply #1 on: June 05, 2009, 11:44:59 »
Hello, Ian,
Welcome to the group.
Filters: These are Mann filter part #s. You can get them from German and Swedish or equivalents from Euro car Parts or local factors:
Air: C15 120
Oil: H720x
Fuel: P707
Plugs: A popular choice is NGK: BP6ES
To get the correct points, you will need the Bosch # on tag on the Distributor.
There are additional seals in the oil filter assembly which should be changed if not recently done.
Have a look at this topic in the wiki.
You need the three with MB part #s given in red
http://www.sl113.org/wiki/Engine/Lubrication
Hope you're enjoying your car already.
Are you a member of the UK MB Owners Club?
There is an 'SL Day' gathering at Castle Howard in Yorks. in August.
Hope this helps.
Happy fixing,
MUR44Y
« Reply #2 on: June 05, 2009, 12:06:36 »
WOW - Thank you... Been looking on line for past 1.5 hours so your advice is much appreciated.
Not a member as yet, only had car about 3 / 4 weeks but am using it nigh on daily and is fantastic fun...
Off to go get parts and find out the other bits I need....
Thank you,
Ian
