Author Topic: 250 engine/230 SL Chassis compatibility  (Read 5175 times)
SNSmith
« on: April 12, 2010, 21:05:20 »
Are the deminsions of a 250 SL engine compatible with a 1965 230 SL chassis? What are the deck heights of each? My 230 SL has a 250 engine that sits high in the frame. The hood will close and latch but comes in contact with the engine. Any correct information is greatly appreciated.
Re: 250 engine/230 SL Chassis compatibility
« Reply #1 on: April 12, 2010, 23:08:40 »
I shall be interested to hear the responses. I thought the blocks etc, were pretty much interchangeable, dimension wise.
« Reply #2 on: April 12, 2010, 23:13:40 »
... My 230 SL has a 250 engine that sits high in the frame. ...
Is it an engine that came from a 250SL or from another car?  If it is from a different model then the side arms could be wrong.
See this for a discussion: http://www.sl113.org/forums/index.php?topic=11554.0
SNSmith
« Reply #3 on: April 12, 2010, 23:27:55 »
Thank you for the information and link Alfred. The issue may be with the side supports. I will consult with my mechanic. In a perfect world I wiould like to find a good 230 SL engine, as this car as been sitting up in excess of 20 years.
menesesjesse
  • USA, MD, Indian Head
« Reply #4 on: April 13, 2010, 02:54:02 »
Engine supports are probably wrong.  I have a set if your interested.  Also, Metric motors took my 250 in exchange for a 230 motor.  Hope this helps.
Jesse
Jesse
1966 Mercedes 230 SL auto
2003 Mercedes E500
1992 Ford F150
1994 Ford Bronco
2019 Shelby GT350R
1967 Mercury Cougar XR7
« Reply #5 on: April 13, 2010, 07:11:25 »
The engine side supports on a sedan must be changed if the engine is used in a SL.  The sedan engine sits about 1/2" higher !
SNSmith
« Reply #6 on: April 13, 2010, 20:11:26 »
Thanks to all once again for the the valuable information. I found the Metric Motors site Jesse, thanks. I may be in touch about the side arm supports.
« Reply #7 on: April 15, 2010, 23:50:55 »
There is an interesting diagram on the SLS web site showing how a misalignment of the drive train or missing plates can lead to the engine sitting too high. Although the text is in German it is clear from the sketch that only the green one is correct.
