Author Topic: Glove Box  (Read 6212 times)
tel76
Glove Box
« on: February 06, 2011, 15:55:01 »
I am in the process of recovering the glove box,in the top right  hand front corner there is a cutout approx: 1 1/2 inch: wide and 1inch deep ,does anyone know what it is for? if it is of no use i will cover it over with material
Eric
graphic66
Re: Glove Box
« Reply #1 on: February 06, 2011, 16:25:33 »
I think it is for the light switch.
  • USA, WI, Mequon
Re: Glove Box
« Reply #2 on: February 06, 2011, 17:53:36 »
Here's a pic
« Last Edit: February 27, 2011, 17:53:06 by thelews »
Re: Glove Box
« Reply #3 on: February 06, 2011, 17:54:44 »
Or Glove box lock lever ???
Naj
bogeyman
  • USA, NE, Omaha
Re: Glove Box
« Reply #4 on: February 06, 2011, 18:50:17 »
Eric, I happen to have mine out and looked - I don't see any purpose either, but my original tex is cut out around that "notch" leaving the painted surface underneath exposed.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
Re: Glove Box
« Reply #5 on: February 06, 2011, 19:37:59 »
As usual Naj got it right.   :)
It is the cut out for the lock lever.
tel76
Re: Glove Box
« Reply #6 on: February 07, 2011, 08:40:08 »
Thank you all,it looks like i will have to keep it.
Alfred, what did you use as a replacement for the cardboard type material used in the bottom?
Eric
Re: Glove Box
« Reply #7 on: February 07, 2011, 17:40:01 »
Aah, the cardboard, "Pappe", or Bernd's holy grail. See: http://www.sl113.org/forums/index.php?topic=11853
I used thin "Irish felt" that is used by boat and ship builders and also by roofing companies  but he was not satisfied with it because it does not have a paper or cardboard feel.
You should be able to get a sample where you are and decide whether you like it.
