Update:
The car works really well and is very fast. I was able to find some AMG technical info specifying that Their 5.0 needs Bosh W7DC spark plugs. My engine is close to theirs as I have used AMG replica camshafts and a tri-Y exhaust manifold system with no cats. So I fitted a set of these spark plugs and it works well.
I had to replace the 3.5 D-jet injectors by a set of 4.5 D-jet injectors so as to be able to use the vacuum actuated fuel pressure regulator and be able to tune Megasquirt a bit better. The system is now in its final configuration and ready for a Dyno tuning session. I will do that when I'm back from mission, may be sometime in December.
Unfortunately, the 3.27 LSD rear end that I had rebuilt has now developed some (a lot of) pinion backlash. I guess I did not sit the races properly and now it all needs to be readjusted. That was my first rear end rebuild, I guess this is how one learns and gains experience. The back U-joint of the prop shaft also has developed quite some play. The car still drives OK, but it's not pleasant. So I unearthed another 3.27 rear end I had (non LSD) and opened it. All bearings and races looked fine in the differential and the spider pin had no play in the diff carrier so I just cleaned everything, replaced all seals as well as the left wheel roller bearing, fitted new grease and a 6.3 sliding joint i had in reserve with a good sliding sleeve, i also replaced the center bearing on a spare prop shaft I had which has good U-joints. i'm now left with painting all this and fitting it in the car. I will then check my LSD 3.27 and may be use it in my Pagoda 5.6 project though I'm planning to go with a 2.85 on that one for now:
http://www.sl113.org/forums/index.php?topic=15521.0At this occasion I will also replace the center heavy duty compesating spring with a normal/softer one as I feel the suspension is a bit too stiff in the back. i will also try to get a bit of negative camber. The compensating spring swap may take care of that. If not, I will have to see what I can do with the center mount: the one i is harder shore which is good to keep the center arm from moving around, but it also keeps it a bit higher than original. I alreasy have the thinnest shims on the suspension springs.
The good news is that the home-made reinforced hybrid 4speed V8/5speed L6 transmission is working really great and smooth, and is handling the power and torque with no problems.
That's all for now.
