Author Topic: stock alternator bracket  (Read 5293 times)
brocksl
« on: June 20, 2012, 00:05:11 »
Frigiking unit now out of the car....wow, that bracket (for compressor & alternator) is huge.  Any ideas on where to find a stock (35 amp) bracket??  Do I need to change pulleys?  Will the crankshaft pulley to power steering pump remain as a direct v belt set-up?  What is the v belt set up with the alternator in it's stock lower RH position.  What v belt is recommended?  Thanks
Re: stock alternator bracket
« Reply #1 on: June 20, 2012, 14:09:26 »
Hello Brock,
New bracket for alternator necessary, see attached.
AFAIK available only used. Ask K&K, Bud's, Dan Caron, Gernold Nisius, SLS and the common usual sources.
Pulleys for crank and alternator should remain the same. Certainly you'll need a new V-belt for the alternator. Don't know exactly what size.
brocksl
« Reply #2 on: June 21, 2012, 11:29:01 »
Hi Achim
Thank you for your reply.....I know Bud's & K&K, but who are the other sources you listed (AFAIK, Dan Caron, Gernold Nisius & SLS) and how do I contact them?
Carl Hans (aka Brock)
« Reply #3 on: June 28, 2012, 21:23:06 »
Hello Carl,
Quote
AFAIK is the abbreviation for "as far as I know"
Dan Caron is a Group member here, his Group's name is Benz Dr., he is also advertiser here:
http://www.sl113.org/forums/index.php?action=profile;u=253
Genold Nisius owns SL Tech in Arundel, Maine:
http://www.sltechw113.com/profile.html
SLS is a Germany-based and here well known dealer for SL parts and other MB passenger cars  :
http://www.sls-hh-catalogue.de/start/index.phtml
« Reply #4 on: July 01, 2012, 10:37:09 »
I'm near Athens, GA 15 min south by High Shoals, I drove out to Bud's and pulled the pulleys off a parts car when I took the Kuehl Meister out of my 230sl. I recall the belt size 9,5x935mm as the alternator belt for non A/C cars.
