Author Topic: Highway RPM's  (Read 9053 times)
Harry
  • USA, TN, Knoxville
Highway RPM's
« on: June 26, 2012, 01:29:58 »
Hi.  My 1966 230SL Automatic is running about 3000 RPM at around 50 - 55 MPH or so.  Seems high to me.  Runs very smooth and actually pretty quiet but that just seems high.  Maybe I'm used to more modern cars that typically boast an overdrive?  Thoughts?
Also, the steering has a good bit of "play".  I read on the forum where the plastic bushing in the coupling is often the culprit and I have that new bushing to install.  I know the old worm gear VW sterring boxes had an adjustment for play.  Does this car offer a similar means to adjust?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Highway RPM's
« Reply #1 on: June 26, 2012, 04:37:58 »
Hi Harry,
Well, you definitely don't want to compare the RPMs to modern cars -- it just won't measure up. That being said, I think 3000 at 50 is a bit high, mine is more like 3000 at 60 or so I think. A lot of this has to do with the ratio of your (car's) rear-end... Mine is 3.75. I'll have to take a ride tomorrow to verify this...   ;)
Re: Highway RPM's
« Reply #2 on: June 26, 2012, 05:50:40 »
Harry,
if you have an axle with a 4.08 differential (as many later 230SLs have) then you are close to 3000 rpm at 55 mph (see attached graph). Especially if your tires are smaller?
« Last Edit: June 26, 2012, 05:55:25 by 66andBlue »
Re: Highway RPM's
« Reply #3 on: June 26, 2012, 08:59:44 »
My Euro version 69 280SL has a 3.92 rear-end.
In 4th gear, the Tachometer and Speedometer needles move parallel to each other.
While tire size may make a small difference, my speed is just about double the Tach reading in hundreds.
So if the Tach is at 3,000 rpm, I'm going about 60 mph; 2,500 rpm is 50 mph. I don't have to look at the speedometer.
This is very handy in a car with a KM speedometer. A glance at the Tach tells me my approximate speed in MPH
without dong a KM to MPH conversion.
Richard M, NYC
Harry
Re: Highway RPM's
« Reply #4 on: June 26, 2012, 10:39:25 »
Thanks very much.  I'll get firmer numbers on the RPM vs speed but it just seemed high the other day.  Where can the differential ratio be found.  I guess mt concern is whether its OK to drive the car at true highway speeds of 70-75 MPH for extended periods of time.  Back when this car was new the speed limit was 75 MPH though.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
  • USA, WI, Mequon
Re: Highway RPM's
« Reply #5 on: June 26, 2012, 11:41:27 »
Harry
Driving these cars at lower rpms for extended periods is bad for them.  You could drive it at 6000 rpm all day long.  It's what they were built for.  The Germans always drove aggressively on their autobahns.
georgem
Re: Highway RPM's
« Reply #6 on: June 26, 2012, 12:03:20 »
That being said, when we first bought ours (4 speed manual) I can`t count the number of times that I found myself trying to change into "top" gear from 4th as the revs seemed high.
George
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
  • USA, WI, Mequon
Re: Highway RPM's
« Reply #7 on: June 26, 2012, 13:54:43 »
George
You've gotten used to the non-interactive nature of many newer cars.  A Lexus is about as neutered a vehicle you can drive.
My 7 speed SL500 lopes down the freeway not much above idling rpms.  With my vintage cars, I won't drive them at any speed under 2K rpm.
Harry
Re: Highway RPM's
« Reply #8 on: June 26, 2012, 16:15:41 »
I checked ain this AM - 2900 RPM at 50 MPH.  I recalled from my youth that these cars ran all day at highway speeds and seemed right at home.  I'll have to get myself "recalibrated".  Thanks very much for the advice and information.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
49er
  • USA, CA, El Dorado Hills
Re: Highway RPM's
« Reply #9 on: June 26, 2012, 16:24:19 »
 My tach has always been a bit on the high side running about showing about 100rpm higher then actual. I Know the feeling about reaching for 5th or 6th gear. Never had a problem when the car was new as it was a jump up from my '65 VW Bug. But after owning a few cars with more gears (and not driving the SL for years) I got used to those low RPMs at freeway speeds.
John
1969 280SL 003820
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Re: Highway RPM's
« Reply #10 on: June 26, 2012, 21:39:34 »
My 71 280SL automatic runs 3000 RPM @ 55 MPH and 3500 RPM @ 65 MPH.
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
DaveB
Re: Highway RPM's
« Reply #11 on: June 26, 2012, 21:50:36 »
Harry - there's a screw and nut arrangement on top of the steering box that looks like it must be for adjustment. But first have someone turn the steering while you watch the coupling between the firewall and the steering box, you'll probably find the play is there, and that the plastic bushings you mention are worn. There are two of them.
DaveB
'65 US 230sl 4-speed, DB190
Paul Robinson
Re: Highway RPM's
« Reply #12 on: June 26, 2012, 22:17:13 »
Harry,
Look for the ratio on a machined surface on the differential housing.  In the case of this 3.27, just forward of the axle on the driver's side.
Paul
