Author Topic: Brightest Headlight Lamps Available?  (Read 5785 times)
250SLFranco
  • USA, OR, Portland
« on: June 05, 2013, 22:42:58 »
I am considering replacing my old headlight lamps.  Has anyone done the research to find out what the brightest lights available for the U.S. might be?
250SLFranco
awolff280sl
  • USA, FL, Sarasota
Re: Brightest Headlight Lamps Available?
« Reply #1 on: June 05, 2013, 23:03:18 »
H4 55/100 halogens work, but the brights are not street legal in the US
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Baybear
  • USA, VA, Midlothian
« Reply #2 on: June 08, 2013, 17:09:41 »
If you want to keep sealed beams the Sylvania Silver Star would work. If you want something brighter the Cibies with an H4 bulb would be a good choice.
Baybear
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
« Reply #3 on: June 08, 2013, 21:01:01 »
Does anyone know off-hand whether the power to the headlights is routed through the light switch in the dash, or whether the switch operates a relay that then channels power to the lights more directly?
Reason for the question is that on US cars of the era changing the wiring to be relay-based is a real upgrade to the intensity of the lights, because there is much less voltage drop.
Don't want to hijack this thread, but the question is related.
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #4 on: June 10, 2013, 00:49:41 »
I just installed a set of the Sylvania Silver Star sealed beams. Huge improvement.
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
« Reply #5 on: June 11, 2013, 01:07:00 »
Dear Cees,
Quote
Yes, I do know off-hand. ;D
The power to the headlight is routed through the push light switch (foot dimmer switch) on the floor well/lower firewall and is left-foot-operated. :o
There is no difference between Euro and US regarding this (but only for the non-connected headlight flasher).
Pls. see the wiring diagramm which I sent you a couple of years back. ;)
Oh, it's in our Wiki :o 8) :D...; you can find it there as well. It's symbol no. 35.
« Reply #6 on: June 11, 2013, 03:53:28 »
Thanks Achim - I knew this must have been detailed in the wiring diagram but I don't have mine handy. As the power goes through that switch as you say, that is probably ok then, the dashboard switch must then direct a relay. So long as the thickness of the wire to and from the foot switch is adequate, there should be no negative effect on the intensity of the lights.
