Author Topic: Hood hinge - body side  (Read 4053 times)
Valvechatter
« on: August 23, 2013, 11:04:55 »
I didn't  receive much response to my first question on tis subject, so let me reword and try one more time.
The hinges for the hood are comprised of two parts: a male bracket with a pin for rotation mounted to the body, and a female bracket that mounts to the hood with two #10 hex head bolts.
My questions is: can the male bracket mounted to the body be adjusted up and down or is it mounted to a fixed plate? I know that the female side has adjustment designed in, but it is harder to tell about the body bracket by visual inspection.
Thank you.
Lin
Re: Hood hinge - body side
« Reply #1 on: August 23, 2013, 12:44:50 »
Hi, Lin,
If you loosen the two mounting bolts that hold the male bracket, it will allow a bit of movement to adjust the bonnet height.
There is a rectangular metal plate in the wheel arch which holds the two bolts, so if you just loosen them enough to get an adjustment, you should be fine.
Naj
« Last Edit: August 23, 2013, 12:55:19 by Naj »
Valvechatter
« Reply #2 on: August 23, 2013, 13:10:10 »
Naj,
Perfect. That is what I was looking and hoping for!
Lin
