C&S = cheap and sleazy
Recent discussion of the dreaded curl, along with some severe curling on my soft top, prompted me to seek a fix that doesn't involve replacing or regluing the top. This is what I came up with. With apologies to puristas...
Download Attachment: CurlFix0.JPG20.42 KB
Download Attachment: CurlFix1.JPG19.12 KB
Download Attachment: CurlFix2.JPG63.2 KB
The pics should be fairly self explanatory. I sewed three 12 inch long (30 cm) pieces of fabric twill tape (1/2 inch (12 mm) wide) to the underside of the curled edge, using a curved sewing needle and nylon upholstery thread. The stitches go through the small loose edge of the top fabric that you'll see there. Not real easy to sew there, but it can be done, and only stabbed myself once
. A neat trick my wife showed me was to fold over the end of the twill tape twice, this gives you a stronger hold on it and prevents fraying.
The twill tape was then held inside the top with the masking tape you see in the second pic, and the top closed, leaving the tapes inside. Hold the curled edge down with a weight or have an assistant hold it down. Inside the car, a plastic spring loaded drawstring catch is slipped over each tape. Snug up each of the drawstring catches until they are wedged between the rear top frame and the top case lid. This, amazingly enough, holds the curl down. The twill tape is on the underside of the curl, so not visible from outside.
If you do this, you will want to put something between the drawstring catches and the case lid to protect the paint. A piece of cloth would probably work, or something similar. That clear plastic stuff that is used to prevent chips in paint and/or headlight lenses might be good, if you want something semi-permanent.
If you put your top up and down a lot, this method might be a bit of nuisance to do every time, and I don't think it is possible to pull the curl down from inside, it needs to be held down outside somehow.
Then go drink a 7-Up, the Uncurla! Sorry, sorry...
