Author Topic: List for No Longer Available Parts Lobby  (Read 50511 times)
Chad
« on: November 27, 2005, 16:14:50 »
(This is an idea that George, Robert Geco, and other active forum members have suggested within the forum discussion recently.)
NO LONGER AVAILABLE PARTS (NLA) LOBBY
Go ahead and list your favorite No Longer Available (NLA) part for lobbying with Classic Center and the usual list of quality suppliers that we use (Millers, Buds, GAHH, many others).  Perhaps during the course of parts ordering many of us do for restoration/ maintenance/ upkeep/ tinkering with can email, phone and write to sound the word and the market to those who certainly do want to know this info to produce it at a reasonable price. These suppliers do simply want to sell us things.
Add each new and unique item to the list with a number prior to it to help with a running talley.
Perhaps this will help every forum member to mention this every time we communicate with the suppliers. Like writing your congressman. It can help the bulk of w113 owners. Cheers and maybe some good can come of it.
-CD-
1967 230SL, 113.042 10
« Last Edit: December 09, 2007, 19:05:28 by Chad »
Chad
Re: List for No Longer Available Parts Lobby
« Reply #1 on: November 27, 2005, 16:15:22 »
(1) Diamond pattern firewall pad in environmentally friendly material.
-CD-
« Reply #2 on: November 27, 2005, 18:02:10 »
Great idea Chad. As president of the Pagoda Group I can take this list to Daimler-Chrysler, perhaps teaming up with the German Pagoda club and the German-language W113 forum, to lobby. The main consideration for parts suppliers is having some indication of demand out there, and this is a great way to gauge that.
iceberg
« Reply #3 on: November 27, 2005, 18:14:43 »
I agree with Chad abou the firewall pad and would also like to add:
(5) The rubber stoppers between the door panels and the door frame.
H
« Last Edit: November 30, 2005, 19:55:27 by rwmastel »
Chad
« Reply #4 on: November 27, 2005, 18:44:12 »
(2) Rubber stoppers (door to door frame) - as per iceberg
(3) Sunvisors (reasonably priced, not a NLA, but World UPH inquired with us about it and don't know if we followed up)
(4) 5 speed transmission (just kidding, but there are probably some common repair parts that you lucky dogs with the ZF could use)
-CD-
George Des
« Reply #5 on: November 27, 2005, 19:29:31 »
Cees/Chad,
I second the diamond pattern firewall pad and there are many others--the sun visors for all the different 113s come to mind. You are right about the ZF 5 speed. At some point all of us who have them are going to need some parts for this. Input shafts, synchronizer rings and assorted aluminum casting parts such as the rear cover plate as well as the gears. Many of the other parts are fairly common bearings, seals and hardware and are readily available. Tailight lenses in all their different configurations will always be needed. The internal parts of the European headlights, particularly the top reflector and the darn clips that hold the glass lens to the h/l assembly. Comprehensive repair parts kits for both style fuel pumps would also help. If Cees can make the contact over there that would be great--I hope others will do as I have and go directly to the Classic Center with a request--all of this may come to nothing, but one never knows until one tries!
George Des
« Reply #6 on: November 28, 2005, 14:51:03 »
I'd suggest:
(6) rubber floormats for 230SL, in all of the originally available colors, and
(7) original style polished stainless wiper blades for same!
« Last Edit: December 01, 2005, 19:08:25 by Mike Hughes »
« Reply #7 on: November 28, 2005, 16:57:35 »
The little rubber stop that goes into the bottom rear of the hard top. Reproduce the red tailights for early 113 chassies. Dash peices new and sun visors for the 280SL. The correct fire wall diamond cut material for the fire wall.
Chad
« Reply #8 on: November 28, 2005, 20:56:37 »
I'd like to see those rubber floor mats for 230 also. They are very period feel, even many of the Astons from the era had rubber mats also. Are we absolutely sure that they are NLA??  I have never inquired.
And stainless wiper blades also!  Again, before adding to the list, are we sure that SLS doesn't carry?
-CD-
gugel
    • CPE Site
« Reply #9 on: November 28, 2005, 21:48:38 »
Early 230SL sunvisors, with the mirror in the right hand one.  I think sunvisors are available, but not with the mirror.
I'd also like to see the rubber floor and trunk mats for the 230SL, in the original colors.
Under dash cladding, also in the original colors.  I've been able to find it only in black.
230SL fuel injection pump thermostat and housing, for a reasonable price.  (I think the thermostat is available, for about $500!)
The BBB in English.
Chris Earnest
« Last Edit: November 28, 2005, 21:52:23 by gugel »
TA250SL
« Reply #10 on: November 28, 2005, 22:18:31 »
Here are a few more NLA items:
ignition key blanks,
passenger door pull handle,
early-style window crank inserts in all colors,
Euro front turn indicator reflectors
Early 1967 250SL
Euro version
Los Angeles
pagode.info
« Reply #11 on: November 29, 2005, 01:06:17 »
The first thing they should do is to put
the EPC(Electronic Parts Catalogue) and
the parts price list (both available on
CD at any Merc dealer)online now.
Lots of parts are still available, but
nobody knows. (Same with 107)
Have a nice day,
www.pagode.info
« Last Edit: November 29, 2005, 01:08:37 by pagode.info »
« Reply #12 on: November 29, 2005, 10:15:12 »
How about the data plates with the option codes and VIN #'s.   Especially the older versions which are more squarish and sit on the firewall and the hand hood release bracket.  Also the small rubber bumpers that sit on the ridge that runs across the firewall(the ones out there are close to the originals).
How about the original 5.5x14 rims with the #113 stamped onto them as well as the 5.5x15 rims too.  I have tried the 15 inchers on my SL and it looks good with extra clearance and would help in the economy too.
Umm, hardtops with sunroofs?  Skiracks?, and other rare options.  Can't a guy dream?
Walter Klatt
1967 220SL diesel
1963 230SL gas nearly stripped
jmela
« Reply #13 on: November 29, 2005, 11:40:50 »
White plastic automatic shift guide insert at a non-extortionate price.
113gray
« Reply #14 on: November 29, 2005, 12:53:48 »
Yeah, 5 speed ZF parts would be wonderful!     -JP-
« Reply #15 on: November 30, 2005, 19:49:50 »
As Chad requested, please use a number to identify your request.  We need to keep this organized.  Please go back and edit your posts to look like the first couple replies.  That is:
(8)  Parts request
(9)  Next parts request
(10)  Some other part
« Last Edit: November 30, 2005, 19:56:22 by rwmastel »
Chad
« Reply #16 on: December 01, 2005, 19:45:58 »
I've just been jotting them down on a notepad along the way. Mentioned to four suppliers already.  I have no idea what to suggest regarding ZF 5speed , but the others are mentioned and they seemed very interested.
Make the list, *and* mention the list to the suppliers, if you think it helpful and you're interested.
Rodd's reminder is very helpful, I think.
-CD-
1967 230SL
« Last Edit: December 01, 2005, 19:46:50 by Chad »
« Reply #17 on: December 04, 2005, 22:47:01 »
Here's my list
original style/quality carpeting
SS screw packages
plastic moulding under chrome strip between tail lights
original firewall pad
tool kit
bosch euro light lenses ( no tooling marks) and other parts
rubber bumpers for hood
original quality leather
« Reply #18 on: January 13, 2006, 12:20:55 »
Yes, my father and I are doing a restore and we need a DRIVERS SIDE SUNVISOR. I have seen beaten and battered ones for $400-$500
I have been mostly looking on E-bay but not having very much luck. Anyone have any ideas of where to get one for not a whole lot of money?
In reasonable shape? 1965 Convert 230SL // off white tanish Colored Interior
KevinC
« Reply #19 on: January 13, 2006, 17:25:49 »
Try this site...www.sls-hh.de
About $250.00 US but brand new..worth it if you are restoring.
Kevin
Download Attachment: MB Sunvisor LH 1.JPG
49.04 KB
Download Attachment: MB Sunvisor LH 2.jpg
14.59 KB
Download Attachment: MB Sunvisor LH 3.jpg
21.12 KB
Kevin Caputo
Boca Raton, FL
1967 230 SL Automatic
670 Light Ivory
113 Bronze/Brown MB Tex
Chad
« Reply #20 on: January 13, 2006, 19:35:08 »
Kay just started a new thread about sourcing these for cheaper, possibly. I will be interested and following that progress through the spring.
If nothing comes of it I think that the SLS price is the lowest I have found also.
I remember World UPH was inquiring of our interest in the sunvisors, but I don't think they have put the product up for sale yet.
« Last Edit: January 13, 2006, 19:35:43 by Chad »
Chad
« Reply #21 on: January 13, 2006, 19:39:59 »
BTW, I just wanted to mention that I had thought the original 230 style MB textured vinyl was NLA, and I suppose it is.... however, the vinyl set I ordered (GAHH) is virtually identical (basketweave and texture/finish) to the vinyl seat covers that were original to the car.  If anyone has a 230 with vinyl originally on it then I would say that GAHH makes a product that is very satisfying if you want to keep the seats vinyl as original.
Chad
« Reply #22 on: January 31, 2006, 00:16:17 »
Apparently the 230 SL chrome rear view mirror (center one inside the windscreen) is also NLA, as far as I can tell as I am trying to find one for replacement.
« Reply #23 on: January 31, 2006, 16:05:39 »
1) firewall pad orginal material & dimond pattern
2) old style red taillights with chrome bezel not glued but remaufactured
3) an assortment of chrome screws always asked for grill. door trim screws
4) dash pad parts offered again.
6)correct heel pad with star for carpet sets
7)hood & door bumpers correct old style
8)hard top handle sets with bearing
9better tecnhical literature
10) sunvisors for 230SL & 280SL
11) hard top rubber seals & correct headliner kit
12) Get Tom Hanson back at the parts counter were we can fine him
« Last Edit: February 01, 2006, 14:15:20 by Bob G »
Chad
« Reply #24 on: January 31, 2006, 20:16:46 »
12) chrome rear view mirror center 230SL style
Do you mean "fine" or "find," Bob??(' :) ')
« Last Edit: January 31, 2006, 21:07:34 by Chad »
