I finished this thread and added to the original message several times to keep it all together. So here is fairly comprehensive document on "timing chain replacement". Feel free to comment or add to the string.
Download Attachment:
chain a begin.JPG58.66 KB (Rodd Masteller and his 230-SL)
We replaced the timing chain in Rodd Masteller's 230-SL last week-end. We took some pictures and documented the process for the group. We will describe the process here during the next few days.
Replacing a timing chain is not that difficult, but the consequences from making a mistake can be catastrophic. We suggest that first timers may not wish to attempt this on their own. One should at least get help or guidance by an experienced technician on the first attempt.
Step number one get the right parts. A valve cover gasket, and valve cover bolt seals should be on hand. The spark plugs will be out so decide if you may wish to replace these also. All W113 engines used the same chain. Part numbers would be nice to add to this document.
Have the correct tools; 27mm socket(22 mm on early cars), a two or three inch extension and a 1/2" rachet handle for turning the crankshaft. A spark plug removal tool. A couple of locking pliers (Vicegrips) are helpful. Assorted metric wrenches (14mm early cars) 13mm, 10mm, a die grinder or Dremel tool to grind off end plates of chain (original chains had no masterlink). Some good strong bare wire to tie off chain ends(wire coat hangers work fine). One or two helpers (at critical times)makes the job much easier.
It is a good idea to disconnect the battery to prevent any accidents.
Remove the crossover linkage by popping the linkage rods going to the injection pump, venturi and accelerator. Next the two 10mm nuts holding the crossover linkage rod in place are removed (notice that these are special 10mm "self centering" nuts, the cone shaped sides must be oriented against the metal during re-assembly). Next the entire crossover linkage rod can be popped out of it's socket on the intake and removed.
Notice that Rodd has popped the intake side of the "crossover linkage" out of it's socket.
chain b remove linkage.JPG60.26 KB
Remove the spark plugs so that the engine can be turned easily by
hand.
After the valve cover vent tube is disconnected and the three valve cover bolts are removed the valve cover is ready to be lifted off. If the valve cover will not clear the hood bracket on the firewall, the engine may have to be lifted with a jack under the bellhousing.
chain c remove valve cover.JPG60.22 KB
The 27mm socket (22mm on early cars) and extension can be fitted on the crankshaft bolt. A 1/2" ratchet handle is fitted to turn the engine by hand. One person working from below and another above is best. Always turn the engine in the normal rotation. Original undisturbed chains had no masterlink and must be broken. Replacement chains have masterlinks.
The chain tensioner sprocket will be visible directly under the camshaft sprocket. The chain tensioner acts on this sprocket to take up normal chain "stretch" or wear over the years. Eventually it extends to its limit and no longer takes up the slack. This tensioner is spring and hydraulically tensioned.
A chain link will have to be broken if no master link is found.
The exposed engine must be protected from any contamination.
chain d grind ends of chain link.JPG61.14 KB
A air die grinder or Dremel tool can be used to grind off the chainlink pins.
chain e secure ends of chain.JPG59.9 KB
Be sure to keep track of the center plate of the link, it will be loose and it could fall into the engine.
chain f split chain.JPG60.33 KB
After the chain is broken, hook a wire to the tensioner side of the chain for pulling. Hook the new chain to the distributer side of the old chain. In addition hook a wire to the other end of the new chain for use later.
chain h feed new chain.JPG58.96 KB
The new chain must be kept in contact with the chain sprocket on the engine so valve timing is not lost. Rodd worked from the intake side of the car. One hand held the new chain tightly against the chain sprocket while the other hand kept tension on the old chain so it would not bunch up and jamb. I slowly turned the crankshaft with a ratchet.
I like to use some Vice Grips to hold the chain tightly in place during the link removal.
Eventually the end of the new chain emerged from the engine. The extra length of wire hooked to it's end became very useful at this point. You want to make sure to always have a firm grasp on both ends since it can be unexpectedly yanked out of your hands at any time.
The new chain will seem too short to connect at first. The chain tensioner must be manually depressed by a steady downward pressure on the tensioner sprocket until the ends of the new timing chain are close enough to connect with the new master link.
chain h new chain in place.JPG62.05 KB
The master link may be the single clip type, the two "c" clip type or the "crimp" style. The first two styles require only no special tools. The crimp style which is becoming more common, require a special crimping tool or must be peened. Be sure to check the master link to see which style you have before beginning.
The two new chain ends are again clamped to the chain sprocket with vice grips or wire. The new mastelink is installed from the front the center plate is a bit thicker than the end plate and it is installed next and lastly the endplate and clip or clips are installed.
chain i connect ends of chain.JPG56.04 KB
Crimp or peen the mastelink pins if you are using this style of masterlink.
The valve timing should always be checked before finishing the job. We turned the engine at least one more revolution by hand to make sure that the alignment notch behind the chain sprocket aligned with the mark on the front cam tower when the engine reached "0" or TDC #1. The valve timing must never be the slightest bit early! It is normal for it to be slightly "late" depending on the condition of the timing chain and cylinder head.
chain j check camshft timing.JPG59.79 KB
Do not ever be tempted to start the engine or crank it with the starter until the camshaft "valve timing" is checked. If the camshaft timing is off the timing chain must be parted and reset.
Before putting everything back together we decided to check Rodd's verticle timing gear and found that it had excessive end play. We removed the bronze/aluminum bushing and found it worn.
chain k check timing gear.JPG63.86 KB We shimmed the gear using a brass injector seal. We re-asembled everything in reverse order.
