with our official
Pagoda SL Group logo
from our official partner.
General Discussion
Speedometer cable - grounding strip
Topic: Speedometer cable - grounding strip (Read 3944 times)
Full Member
Platinum
USA, CA, Solana Beach
July 02, 2007, 13:33:42 »
I am in the process of installing a new speedo cable and the old tachdrive cable again and have a question about the grounding strip (see picture). Whereas the clamp on the speedo cable touched the bare metal sheeth the one on the tach cable did not.
Questions: should I remove the plastic cover on the tach cable to make sure it is also grounded? The new speedo cable does not have the bare spot, so I guess, I should remove the plastic and replicate the old one.
:?: Why do these cables need to be grounded :?: There are ground cables on the instrument cluster in addition.
Download Attachment:
52.86 KB
Last Edit: July 02, 2007, 20:38:49 by 66andBlue
1966 230SL automatic 334G light blue (
sold
merrill
Full Member
Platinum
USA, TX, Austin
Re: Speedometer cable - grounding strip
July 02, 2007, 18:52:09 »
Alfred,
i do not know if that is a groind cable, but on my 230 sl it bolts to the firewll with a screw, just to the drivers side of the upper speedo cable hole.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
Full Member
Platinum
USA, TX, Austin
Reply #2 on:
July 02, 2007, 18:56:40 »
alfred,
sorry, I did not answer your question., on my car this holds the cable to hold the hood. this is not on the speedo or tach cable.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Full Member
Platinum
Reply #3 on:
July 02, 2007, 20:43:52 »
Matt,
on my car there are clearly two copper mesh ground straps both bolted to the same bare spot on the firewall. One is attached to the tachometer cable (but not touching the metal sheeth) and also to the temperature sensing capillary. The other is attached to speedometer cable, touching the metal sheeth. I have changed the picture in my original post to show that it is not the cable that releases the hood.
I wonder if anybody else has these straps?
sold
General Discussion
