Author Topic: JACKING CAR  (Read 7925 times)
RBYCC
JACKING CAR
« on: February 07, 2008, 09:34:02 »
What are the best points front and rear to place a hydraulic floor jack?
Also placement of jack stands....below chassis jacking points?
Thanks !
ED A.
1988 300CE TWIN TURBO
1990 C43 AMG
2003 G55 AMG
Re: JACKING CAR
« Reply #1 on: February 07, 2008, 14:14:55 »
Ed,
here is a picture that Joe Alexander sent me some time ago:
RBYCC
Re: JACKING CAR
« Reply #2 on: February 07, 2008, 14:51:59 »
Ed,
Much thanks !!!
That solves the rear.....any recommended points for the front?
Thanks again !!!
Ed A.
ED A.
1990 C43 AMG
2003 G55 AMG
merrill
Re: JACKING CAR
« Reply #3 on: February 07, 2008, 19:08:02 »
for the front it depends on what you are doing.
typically you can jack and put stands under the sub frame behind the oil pan.  this keeps the subframe mounts from holding up the entire
weight of the motor.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
RBYCC
Re: JACKING CAR
« Reply #4 on: February 07, 2008, 20:18:48 »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Thanks Matt
I thought that was a good location, but just wanted confirmation.
ED A.
1990 C43 AMG
2003 G55 AMG
280sl1968
Re: JACKING CAR
« Reply #5 on: July 02, 2010, 06:41:56 »
Sorry to resurrect this one, but looking at the picture above, it seems to suggest that the torque arm itself is a suitable place to jack the rear of the car.
What little my Haynes manual says about jacking, it does say "Never jack up under the rear suspension link arms". I assume they are referring to the same thing, so I was just curious, which is right?
As I want to place axle stands at the torque arm mounting points, I guess it only leaves under the diff as the remaining 'safe' place as a jack point?
David
