Author Topic: RHD drivers side poor carpet fit around pedal  (Read 5824 times)
DB280
« on: September 01, 2008, 07:46:52 »
I purchased a carpet set from Germany.The fit is perfect apart from where the throttle pedal is as photo shows.The Company say the pedal is in the wrong place and should be 3 to 4 cm away from the side.
Any advice gratefully received.
Thank you
Download Attachment: throttle pedal.jpg
128.36 KB
« Last Edit: September 04, 2008, 08:30:38 by DB280 »
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
Re: RHD drivers side poor carpet fit around pedal
« Reply #1 on: September 01, 2008, 15:45:17 »
I believe they are correct see my post on the gas pedal bracket...It ends up about 2-3 inches from the center tunnel.  THIS IS ON A LEFT HAND DRIVE.
Hope that helps
Bob "Baron" Youngman
1965 220se coupe restomod
Val
« Reply #2 on: September 01, 2008, 16:01:06 »
I believe your pedal is correct and the supplier is wrong  :(
Who are they?
(think its time I got the vacuum out  ;)
« Reply #3 on: September 01, 2008, 19:33:04 »
Here is another to confirm Val's from Manual
« Reply #4 on: September 02, 2008, 02:35:48 »
Mine too is as near as dammit touching the sidewall
DB280
« Reply #5 on: September 03, 2008, 12:31:46 »
Update.
Thanks to the members who have replied.I passed on the info and photos to the company concerned and have had no reply as yet.I shall be naming names soon and also asking the UK MB club to remove them from the recomended list if I can't get a reply by the end of the week.
