W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: healey100 on August 03, 2009, 18:33:35
I have a 23o SL 1965 and the oil deepstick 220 SE is this the correct one or should be another one?
It depends? I have the same dipstick on my 1965. Yours and I believe it is right if the engine number indicates a SL motor. If your engine number is a 127.980 you probably have a 220se motor from a different car but a 127.981 number will indicate a SL motor. They are essentially the same so the dipstick is shared part as far as i know.
Thank you for the information, the engine is 127.981.
The 230SL engine is based upon a highly modified 220SEb. All the early cars use 220SEb style dipsticks.
Thank you very much for your help.
