W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: immelmann on August 15, 2009, 08:34:47
Hello all!
I am doing a overhaul of a fuel pump of the 'new' type. The Bosch number is 0442201002. I searched the forum and got a MB number A0005860147, i got the same at EPC. But when i check with http://et.mercedes-benz-clubs.com/en/result.jsp?locale=en&a=search&partno=A0010915201&x=27&y=7 for the price the article does not show up. For me it is that the part is not sold by MB anymore. Its that the facts? If so, witch o-rings must be square cross section?
I intend to use it for my 220SE sedan from 1959 until i have restored the original one.
Thomas
Thomas,
The repair kit sold by MB has a very minimum of parts. As I recall, all you get with the kit is the large o-ring for the bottom, a small o-ring that cushions the nose piece of the motor section in the pump section and perhaps the motor can seal. You also get the brushes, but also as I recall, the brushes sold with the kit do not have a "cut-out" which allows easy installation of the brushes. The only o-rings on the pump with a square cross section are the two rings that seal the brown and red terminals--these are not included with the kit so if you have a leak here you need to source the square ones elsewhere or use the round cross section rings with perhaps some fuel resistant sealer to "help" them. Ideally, the kit would contain all the o-rings, the screws, nuts and washers, new brushes w/the cut-out, new brush springs and new metal and fibre shims. See the tech manual for the rebuild procedures.
George Des
Des, do know the sizes of the various o-rings? The largest should be 2 mm i believe but the 58 mm i don't know.
Thomas
Hello Thomas,
Denny Denio was at PUB and had a whole bag of the correct metric o-rings he had sourced individually. He had all the sizes and diameters. These may have been for the early pump, however his source should be able to supply the orings for the later pump also. I believe it was Maryland Metrics? Now all you need are the sizes.
Thanks Joe, maybe Denny Denio can contact me about the sizes because i trying to locate the rings locally.
Anyone know Denny Denio's e-mail address?
Thomas
No, but his handle is "pagoden".
Thomas,
I'm sorry I can't give you a simple direct answer but will help as I can.
When I began my parts search for rebuilding my old/tall pump I used the pretty fabulous article in our Tech Manual [by Bob Smith, citing Naj and George Des as well] for parts specifications. It lists the bearings and brushes as well as the O-rings, sometimes by MB part #, sometimes by measurement in inches. When an MB# is given, the BS # is given as well. I learned that "BS" refers to British Standard, a system that makes perfect sense in Bob's homeland of Australia. And maybe, with your proximity to the British Isles, those numbers will work for you more directly. For us in the US, I learned also, O-rings are specified using their diametric dimension in inches. (A second number specifies the thickness of the 'rubber' material and is given in millimeters! -- 1 , 1.5 , 2 in our applications.) The "N70" which appears often refers to the material most often specified for use with petroleum-based fuels. As my situation here called for inch-fractional descriptions I was frustrated until I came across an business in Australia which (bless their hearts) posts a Rosetta Stone chart giving inch equivalents to BS designations. I ordered my O-rings from a US supplier using measurements in inches; supplier taught me that that is how it's done, at least here. Again, you may be able to work back from Bob's numbers (in the 'old/tall' section of our TM under Fuel Pumps) more directly to original specifications in what ought to be metric measurements.
When I made my first call --to the MB US Classic Center-- I was told that these pumps are not rebuildable because the O-rings are NLA. Using the MB#s Bob, George & Naj have provided us I got a more positive response: yes, they are available -- at approximately USD 23 ..... each. And we don't have the MB #s for all of them, so I went looking, as above. In the end I bought complete sets for about USD 1.5! That supplier --Maryland Metrics in Baltimore, Maryland, USA-- does have a minimum charge per order as well as a minimum shipping/handling charge, which would raise the final price for the set to nearly the same price that MB asks for one of the larger 'rings.
[ I got around those minimums by asking my daughter, a student in Baltimore, to pick up my order in person and bring it home on one of her visits. This errand to an unfamiliar part of the city combined with a moments' inattention on her part to result in a fender-bender traffic accident which raised the price of my 'rings past casual calculation. (All parties are in fine physical condition but all the returns on that one are not yet in.) ]
I kept a set for myself. The other two went to JA17 and Waqas at Blacklick PUB, after which I had time only to drive the near-1000 kilometers home, unpack, do laundry, repack and catch a flight back out here to my wife in the midst of North America where we are looking after the affairs of our extended families. The result of that mad dash is that the O-rings, my notes and the supplier's invoice are all neatly tucked away in the garage at home, some 2000 kilometers from where I am this week. "It seemed like a good idea at the time." Alas and alack.
Upside: Waqas divided the original order for me during PUB and may well have recorded the dimensions for his own use in future. And a recent reading of George Des's section on the 'new/short' pump shows his complete familiarity with both pumps and can tell us whether they both use the same O-rings, as I believe they do.
[Nearly none of my results translated into even metric measurements, which seems odd given that the pumps must have been designed under the metric system. I tried to 'fudge' my results into round numbers in the metric system but they 'didn't want to go'; I don't know what to make of that. Another consideration is that the 'rings come in very fine increments of overall size, and will happily stretch a little; at a few pfennig apiece you can work to come close and then try a couple. And the diameter of 'rubber' stock is simple, with only one or two choices being reasonable for any given application. And take measurements from your pump, come to think of it! :-[ ] Combine all of that and you will come up with answers at least as good as mine. And best of luck with the disassembly!
Thomas, I'm very sorry --and frustrated-- not to be able to give you better answers now. If you have no luck and are engaged in other work on your auto and can work around this project, then in a few weeks I can be specific about what I learned. (I even have hope that you might be able to improve on our information by going more directly from the MB (or even BS) numbers to the original metric specifications.)
Regards and good wishes,
Denny
PS - Anyone wishing to email me before the first week or so in September should use denioj2000@yahoo.com as nothing
else seems to work here or in many other locations, another challenge for later as our providers seem helpless to help.
Hey Denny,
Thanks again for the entertaining ride from the airport!
Chan
Denny,
You are right about the o-rings being able to stretch a bit to fit. The o-ring for the bottom plate of both pumps is the same. I will have to take a close look at what I have been using but I know they all need to be stretched into place and this is not a problem as long as they are nitrile o-rings which are fuel resistant. They are all readily available and i'm sure you can even use a non-metric ring if it is close in size. Others have used Viton, but this is really overkill.
George Des
Denny, I called my part supplier at the local MB dealer in my town and they had the repair kit available for 20$. So I ordered one kit and then I can measure those rings and give the group that info. I have already replaced the three small ones.
Thomas
immelmann,
Would you mind posting the part number for the kit?
Charlie
Correction, I just picked up my rep.kit yesterday and it was only the carbon brushes in that kit. Mercedes sells the rings a part for 27$ each! They also changed the parts number. I will post it after work.
I will try to see if I can get those rings from a supplier in my hometown.
Thomas
The number A000 586 0147 for the rep.kit fuel pump is obsolete according to my local MB dealer. The new number is A000 548 0442 and only includes the carbon brushes. However, the EPC shows the number for the rings but the pump looks the old larger style. Those numbers are, largest has A0049970445 , second large A0009979145, both up to chassis 010241. Anyone now what happened after that VIN?
Thomas
Thomas,
Another development:
Just received my copy of Pagoda Notes [Volume 3, Number 3] as forwarded by our daughter from home (so that maybe yours is arriving soon as well). This issue has more info on rebuilding the new/short pump.
Some of the numbers in this article (dimensions; I have not compared part #s) are slightly different from what I recall, though they are very nearly the same. And, of course, 'my' numbers 'have a lot of miles on them'(have been through several conversions). Again, I'm pretty comfortable with my numbers (all hidden away in the garage :-[) but hopeful that, from your base in Europe, you will be able to get to the original specs in millimeters, in which the pumps surely were originally designed.
Yeah; those are some pretty amazing prices for little rings of 'rubber', eh? Think of it by the pound and it probably makes, say, front grill parts look positively affordable, yes? Gotta think positive. ;D
There's a 3-part dimension ("8,5x13x2") given at the middle of page 3 in that new PN issue which puzzles me: I don't know what to do with 3-part specs; as in earlier post, I only know to specify overall diameter & diameter (thickness) of the material itself. ??? Or does this refer to Inside Diameter, Outside Diameter & Thickness? -- a sort of rubber washer? That works in my mind, but the accompanying narrative refers to it as an O-ring --- again: ???.
It looks like the square-section seals at the electrical terminals are going to be a problem, at least down the road. This hasn't concerned me as my focus is on my old-style pump (which, having no fuel in motor area, can't leak from there) but if/when I get their dimensions I'll pursue them. [and now I wonder if we already have them: 8,5x13x2 , as on p.3 of newest PN, referred to above. And we can at least approximate that at a well-stocked hardware store -- that is, IF their "neoprene" is fuel-proof.]
I'll bet the old, seldom-seen parts reference tomes that spell out the original specs for all these little devils we're chasing exist in several settings around the world. How great would it be for some folk to open 'em up, even take pleasure in a little detective work; with the right book it would be so easy it might not even be very interesting. Sigh. And while we're fantasizing, how about the day when we finally get all this into the Tech Manual?
[Dear Peter: the TM is already more and more amazing; thanks very much to you and all the others.]
Good hunting, Thomas,
Denny
Chan,
You're most welcome, and pretty easily entertained as well. (Actually, I think I was beginning to run pretty much on empty by about that time, so was possibly a bit more 'entertaining' than on, say, an average Wednesday. And over the next few days it didn't improve much, at least in that respect, as the axle was laid bare, parts were ordered 'overnight express' from across the continent ... and then didn't show up for a couple of days; all very character-building. (Axle still at Joe's, still in pieces; becoming a very looong story.)
But Mary & Joe such great hosts, yes? And so fine to meet good folk. I've been told several times by owners of these and other fine (and not-so-fabulous) marques that the value is in the people you meet, and PUB '09 certainly brought that home for me. A lot of really nice iron (& aluminum) too, of course. ;~) All in all a great pleasure. Thanks for the shout, Chan,
Denny
Denny,
you can add stuff to the Technical Manual on these washers and other experiences yourself.
Peter,
I'd be pleased to make a valid contribution to an article that's already quite valuable, and had thought I might do so when I get back to my notes in a few weeks. But I think, too, that all of us who're currently worrying this bone would like to have better --or at least better-consolidated-- information than we do now. George is obviously very familiar with the whole subject but is suffering from 'long-term memory loss'; sounds like he's checking back on a couple of things he can't recall with confidence as so much has passed through his mind since he was last focused on fuel pump O-rings.
Another perspective just showed up as an excellent tour in the newest Pagoda Notes; we have had George Des, Bob Smith, Naj, Albert, Achim, Eugene, Joe A., Abbas (& others, I'm sure) contributing on this. (I haven't even opened up my pump yet.) We seem very close; I have the feeling that the accurate information we need is available among us now --or soon will be-- and needs mostly to be pinned down and recorded --- in the Tech Manual, certainly.
Surely the definitive specs must have been originally rendered using the metric system. The fact that I'm not able to physically access my 'inch-based' specs for another fortnight or so prevents me from posting them to the TM. Thomas (Immelmann) is currently the most motivated inquisitor on the topic, and he's in a metric culture, close to the original source. There are several 'old hands' with impressive knowledge individually & collectively whom we can hope will connect with him in this new thread. I am in hopes that we'll have O-ring specifications worthy of inclusion in the TM before I can get my hands on the inch-fractional stuff I scraped together.
[By all means delete as personal traffic 'after a decent interval', as thou see'st fit.] ;~)
Denny
I came across the notes I kept with regards to the O-ring kit that Denny kindly gave me at PUB'09:
Diameter | Thickness | Quantity |
5.00mm | 1.0mm | 1 |
53.67mm | 1.78mm | 2 |
5.00mm | 1.2mm | 1 |
36.27mm | 1.78mm | 2 |
69.57mm | 1.78mm | 1 |
3.75mm | 1.8mm | 2 |
The dimensions and quantities are from Denny. I am unsure whether the diameters are ID or OD.
I have not tried to rebuild any pumps with these O-rings, so the particulars remain unverified by me.
Also, please remember that all O-ring rubber is not created equal. I imagine it should be fuel-rated material.
http://www.oringswest.com/
Look under metric.
Waqas, Michael and Thomas,
That's great, guys; the cause is furthered. Waqas' data jogs my memory and Michael's website gives us an excellent product offering in metric specs, something I didn't find in my searches. (Must keep in mind that only a few of the sizes are given in metric in our TM; the tricky ones -for some of us, at least- are in British Standard and/or MB part # --and those are the ones costing close to $25 each when available from MB.) My notes reflect the chase down those rabbit-holes, ending up in inch-fractional because that's what the supplier in Maryland works from – it’s even the way the O-rings I bought are referred to on the purchase invoice: no part #s or other reference. But of course our pumps are metric and pretty much have to use metric 'rings, and in whole-number sizes for the most part. Now the pursuit turns to the metric....finally.
Waqas, it looks like you picked out a page of notes from part-way through my earlier odyssey, most likely looking to have specifications in metric notation. But those numbers reflect precise equivalents to specifications in other conventions and I think are likely not available as product in those exact sizes. Now that Michael shows us what's available in metric O-ring product; we can verify with measurements from actual pumps and hopefully someone will eventually put the authoritative seal on it with the factory specs from some arcane MB reference materials. Meantime, although I think the inch-fractionals will serve to build a pump, surely all would prefer our O-rings in metric specs.
The material in the O-rings I bought from Maryland Metrics is Nitrile 70, the industry standard for service in petroleum-exposed applications, with specific mention of fuels. The premium material most readily available is Vitron, which is apparently a bit less convenient to get in all sizes, more expensive and considered by most --including our TM-- to be unnecessary overkill. (The originals went 30+ years, after all.) The 5mm sealing O-ring on the impeller shaft of the old/tall pumps might be one place where Vitron could add, since failure at that point on those pumps seems to be pretty much the only cause of pump failure save for gelled fuel crud in the impeller chamber. I really don't know anything of Vitron's possibly enhanced performance as a seal on spinning shafts, but it would be interesting to know.
O-ring sizing convention is by inside diameter. The smallest number -- given second in many cases, first in others-- gives the diameter, or cross-section, of the material itself. (I haven't been using 'cross-section' but think it's better for clarity, will start now. Another bit of help from Michael's O-ring West site.)
In order of disassembly as dealt with in the TM: Old Pump [5mm shaft seals at the end.]
* Largest 'ring, located inside the cover of the impeller chamber. 2mm cross-section ("CS" on O-Rings West charts) and an inside diameter of (most likely) 70mm. The article in our latest Pagoda Notes (George, Abbas and Eugene) refers to this one as being 70mm in the new style pump and gives an MB part # as well.
Note: our parts list needs to become two lists, as the old and new pumps call not so much for different sizes of 'rings' --I think-- as differing numbers of each. Sizes 67 through 73, etc. are available in 1mm increments. Seems likely to be 70mm for both pump styles.
[PN article also refers to another large 'ring which appears only on the newer pump; on p.3 it refers to both large 'rings, giving one the 70mm size and the other 71mm. I’m surprised to see these O-rings vary by just 1 mm; normally you’d expect them to be identical absent any outside influence requiring variation.]
NOTE: this is certainly a learning curve for me. I had been focused on the old/tall pump because mine leaks. The PN article treats the new/short pump. It becomes apparent that the old one has a cap/lid on the motor chamber while the newer model's motor does not, coming away from the impeller 'department' as a closed-ended "can". It appears that old/tall pumps will need just one of the large 'rings and the newer/short style takes 2 of them. Please forgive my being over my depth here, and recall that my original intent was merely to equip myself with 0-rings for going into my own leaky pump -- which sits, leaking still, and I, far removed from it, can only infer and extrapolate. Oh sigh.
* In the older pumps there are 2 middle-sized O-rings sealing the motor area, between the pump and motor section and between the cylinder containing the armature and that cylinder's end cap. These are the 53.67mm 'rings in Waqas' list. The "O- Rings West" site lists 54mm x 2 and its neighbors as available in 1mm increments. The Pagoda Notes article identifies the one on that new-style pump as 57mm x 2 (between the motor 'can' and pump areas). Here we may have a problem. My dimensions for these 'rings on the old/tall pumps come from the TM rebuild (Bob Smith), given as a British Standard coding and developed by me through inch/fractional dimensions to the metric equivalent --54mm, unless I messed up somewhere in the process. (I can review that process, but not for weeks.) It seems reasonable that the dimension here might change with re-design of the motor, but a little odd if the change is to a larger diameter for a pump in which the field winding is no longer present; not impossible, just non-intuitive. I found no dimensional information on this 'ring in the recent Pagoda Notes article, though certainly much other good info.
This area is the most problematic in terms of getting to the exact specs we're seeking and points up the need for someone with a metric caliper and disassembled pumps of both styles -- and/or loads of experience with them -- to contribute from empirical knowledge by verifying all these diameters against the pump’s hard parts.
* Smaller of the major-sized 'rings. Applications: inlet and outlet covers, totaling 2. No drama here, one hopes. 36.27 x 2 as posted by Waqas. Michael's referral shows O-rings from 35.50mm through 38.00 by half-mm steps. I’m guessing 36mm for these; 36.5mm is also available. (The newer pumps break down differently in this area and may well require a different-sized pair of ‘rings at their ports. I haven’t found any mention of what dimensions are required here – and perhaps they use a different type of seal altogether.)
* Inside the top cover, 2 small O-rings are found on the studs. O-Rings West offers 2mm by 3.00 through 4.50 and beyond in half-millimeter increments. Looks like a toss-up between 3.50 and 4.00. Apparently none of these on short pumps.
* Shaft seal, 5mm x 1mm Just one is required, and only in the old-style pump. This is what the bellows seal works against, and some of our fellows have written of custom-sanding these 'rings for a better fit. When my supplier’s site offered another 5mm 'ring of a very slightly thicker cross-section I thought it might be useful for such custom fitting. 5mm x 1mm is given in our TM.
*? Shaft seal, 5mm x 1.5mm The O-Rings West site offers this thicker cross-section alternative. [the increase in the inch-fractional ‘rings I got was much less than the 50% bump available in metric.]
The 2 square cross-section seals at the electrical connections don't seem to be applicable to the old/tall pump. They do seem to be a challenge that will plague us increasingly in future newer-pump rebuilds.
O-Rings West imposes a $50 minimum charge per order of each metric size, so we still need a supplier as well as more precise and well-organized specifications. My Maryland Metrics supplier imposes $10 minimums, both for shipping and complete shipped orders; much better. And I can avoid that with pickup at their walk-in order desk.
But first I've got to get to the bottom of an apparent contradiction: how is it that a business named "Maryland Metrics" can only supply O-rings in English/inch specs? Surely there has been some failure to communicate. I’ll check it out.
Thomas, how goes it with you? Good heavens man, look what you’ve started. Actually, of course, it’s all been going on for some time; you just stirred it, which seems timely and welcome. Hopefully we can subdue the beast shortly, and you and I can enjoy our refurbished pumps……next spring? :o)
I think I can contribute little more to this quest, at least for now. And I’ll be offline for a little as well. Regards to all.
Denny
Small point--- The o-rings on the long studs going thru the top cap above the brushes. They were on the outside of the top cap on a pump I just took apart. The cap went on the studs. o-rings next, metal washers next, then the nuts. If they went on the inside, what do they seal against? IMWTK
Denny, I got the data off the Maryland Metrics invoice you had with you.
To give my 2 cents worth I like to use "quad" rings on rotating shaft. Quad rings come in the same metric or dash sizes & materials as round cross section o-rings. The benefit to using a quad ring is that they have 4 distinct sealing lips, In the case of the pump motor shaft 2 sealing surfaces would be in contact with the spinning shaft. Unfortunately quad rings are a little tougher to find. Here is a link to a quad ring catalog.
http://www.metric-seals.com/catalog/AdvancedWebPage.aspx?CategoryText1=Quad%20Rings®&SBCatPage=&FromPage=1
Geezer, Waqas
Quads sound like good sense for that application and are probably the answer for the electrical terminal seals on the wet-motor pumps as well. Nifty. (Nobody really says that, do they?)
[FWIW, could not open the 'Quad' listing on Metric Seal, Inc. site (via the link provided); may just be on my end, as there's a lot I can't do out here in the country's middle parts, which all remains mysterious -- must go home, see how it works there.]
Reached Metric Seal's website through basic web search; looks very promising.
Sorry Waqas; my mistake; those figures look like the sort of thing I got while converting from inch/fractionals. I still don't have those guys at Maryland Metrics figured out. Seems to me they have to stock O-rings in even - mm sizes, and that original M-B (and supplier) designers worked in even metric dimensions, at least in sizes over, say, 10 mm. Also seems odd to put specs like those on an invoice. Will pursue it.
Denny
This is a real old topic but nonetheless I'm sure there are still those out there with problems figuring out how to solve the issue of leaky seals around theelectrical terminals of the shorter fuel pump. This has been an issue with many of these pumps and the only good solution is to find a square profile oring that will fit into the recess and seal the terminal root. I did some searching around and found some square profile rings on McMaster Carr, but they were all in inch sizes and after testing a few different sizes found that none of them fit the bill. Likewise, some metric round profile rings with similar results. So here's what I did. I noticed that quite a few oring suppliers also supply oring cord in bulk lengths where you can make your own orings by cutting to length and super gluing the edges. I was skeptical of this but did some research and found it is an acceptable way of making custom fit orings, particularly if the ring is to be used in a static situation like the terminal seals. I took an AS568-012S, which is a square profile ring, and cut out a very small wedge shaped section with a razor knife. I glued the edges together, fit two of them to the pump terminal area and coated them with a small amount of Permatex 2 gasket maker and ran the pump for about an hour with no leaks. Some super glues are better at this than others, Locktite 404 is pretty much the gold standard for oring making, but is not cheap--about $25.00 for 1/3 ounce but that should last a long time. hope this helps those with leaky terminal seal issues.
George Desiderio
