W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Larry & Norma on May 20, 2010, 18:08:06
Title: Terminal strip
Post by: Larry & Norma on May 20, 2010, 18:08:06
Hi. There is a 3 way terminal strip mounted under the alternator. What are these connections for please?
Title: Re: Terminal strip
Post by: al_lieffring on May 22, 2010, 20:55:05
It is a break in the wiring harness of the starter motor from the main harness, It is only found in later model cars.
Post by: Larry & Norma on May 23, 2010, 08:55:17
Thanks Al. Another mystery solved!
