W113 Pagoda SL Group => Electrical and Instruments => Topic started by: loizou on July 31, 2010, 21:40:16
Title: Fuse blowing
Post by: loizou on July 31, 2010, 21:40:16
No 8 fuse is blowing every time light switch is turned on any ideas please.
And can someone tell me what wattage the license plate bulbs are. Thanks
Title: Re: Fuse blowing
Post by: Jonny B on July 31, 2010, 23:16:51
Did this just start? Had the lights been out, and you are now working to try to get everything working alright?
I had a similar problem with my car, and finally found that the wires in the connectors (in the trunk) were switched! It was grounding out, and every time I put in a fuse, pow, it blew.
or is there a break or some other touch point in the wiring that is grounding out the connections?
Post by: loizou on August 01, 2010, 00:15:39
Just had some bodywork done and went to fit the rear lights and it started to happen only on the left side of the car as we went to fit the connectors BTW the connectors were not taken apart.
Post by: Witt on August 01, 2010, 03:41:14
....... Having been in the automotive repair business for some twenty odd years, before my retirement, I have yet to see a bodyshop that is reconnecting wires correctly after they are finished with there work.
On every older German car, as far as I know, the ground wires are BROWN !!! Most of the time the black wire, that is live, is mistaken for the ground wire hence fuses popping galore....
CHEERS !
WITT !  ;)
Post by: Richard Madison on August 01, 2010, 12:15:36
There are wiring diagrams an article on fuses and more in the Tech Manual.
Richard M, NYC
