W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: mfriedman on February 17, 2011, 17:40:02
Title: Stuck WRD
Post by: mfriedman on February 17, 2011, 17:40:02
Dose anyone know a way to free up a stuck WRD plunger? After immersing in boiling water the plunger only moved out about 1/4". Thank you!
Title: Re: Stuck WRD
Post by: 66andBlue on February 17, 2011, 18:09:07
As far as I know that is the distance you can expect.
Search and you will find: http://www.sl113.org/forums/index.php?topic=9244.0
Which WRD do you have, early one or current one?
It would be very helpful if you add an automatic "signature' to you posts telling us what car you have.  ;)
Post by: mfriedman on February 17, 2011, 18:18:05
I have a 1965 230sl, still learning to post properly.
Post by: 66andBlue on February 17, 2011, 20:56:19
no problem you'll be an expert soon!  ;)
Since you have a 230SL it is most likely that you have an early IP (R11) with the very old style thermostat:
http://www.sl113.org/wiki/Fuel/Injection#Pump.
A photo of the sensor is shown in this topic: http://www.sl113.org/forums/index.php?topic=5460.
Note that internal plunger (a wax filled cylinder) is longer than in later ones. You cannot buy it anymore so be very careful!
Here is a photo of the later sensors: http://www.sl113.org/forums/uploaded/WillS/200612815248_IP_Therm_Arrows.jpg
