W113 Pagoda SL Group => Electrical and Instruments => Topic started by: paults1 on April 13, 2011, 01:47:13
Would there be sufficent ground if I installed the ground wire on the back of the Tach. housing instead of under the 'C' bracket krunled knob. I can use a nut to secure the wire on the back of the housing on the same threaded piece that secures 'C' the bracket. This would enable an easier installtion of the Tach.
Paul
Should be fine, just check for continuity between the old and new connection points with an ohmeter.
