W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Didier on May 30, 2012, 19:20:21
Hi there,
I am restoring my second Pagoda, but her=ar I am getting stuck. I have dismantled and put back and automatic gearbox on a 280SL. Could someone explain to me how it is possible that when I engage the reverse gear, the car goes forward? Anything electrical? I have set the lever correctly though.
Didier
Most likely you have the linkage to the transmission mis-adjusted. Also if you replaced the plastic bushing on the lever on the side of the transmission, make sure you have put it into the correct hole.
