W113 Pagoda SL Group => General Discussion => Topic started by: swampdog on October 24, 2012, 16:09:58
Title: I need help. I don't know whether to sell car or push into ocean & sell parts
Post by: swampdog on October 24, 2012, 16:09:58
I need help.  I don't know what to do next.  I was told this forum is the experts and would know what I should do.  I have a 230SL ground-up restoration on the home stretch that got derailed due to stolen gas tank and mis-welded quarter panel.  I have since gotten a new gas tank but the 1/4 panel is still welded on crooked and the project is covered in 17 years of dust.  I have an attic full of new parts.  It's time to cut my losses and move on.  Here's the full story.
I bought a 1967 230SL european left hand drive in 1989 for restoration.  I have a clear georgia title but it has not been registered since I movbed to florida in 1994.
As I was dismantling the car at start of project, I came across a very good buy on sheetmetal - $1200 for two new fenders, two new quarter panels, two headlight cans, and a nose bridge.  So I went ahead and cut off the old sheetmetal put the car on a giant rotisierre and sandblasted the unibody frame.  I did the hood, doors, and decklid myself with a 5hp compressor running lower pressure to avoid warping.  The original body did not have any bondo indicating wrecks or dings.  It had lead in the weld seams but was otherwise just old metal with some rusting in the splashwells and in the space between rocker panel and unibody frame.
The blasted unibody was etched, shot with black epoxy primer, and undercoated.  Transmission tunnel
and underneath sides fender/quarter were painted with standard PPG AE paint in the orginal tan color.  The engine and injector pump was rebuilt in Atlanta by some guy called Ron who did the work for Bud's Benz.  The rebuilt drivetrain, suspension, and brakes were installed sans plumbing, radiators, electrical, and master cylinders.  The 4 spd transmission was not rebuilt.  New clutch components were used.  The differential was not rebuilt either.  I can't remember if I put in new u-joints or not.  The brake hydraulics are plugged at end of flexible hose and the engine openings are taped over.  The interior is 100% bare.
The car was sent to atlanta st. welding to have panels welded back on, the gas tank and hardtop frame were sent to a dip-n-strip specializing in old cars, and the seats were sent to buds benz for new padding and burgundy leather.  Enough leather was acquired to refinsh all panels.  By that time I had also collected nearly all the parts needed such as new rubber, new lighting, new carpet, new top, exterior chrome, alloy wheels, front wiring harness with fuse box(the old one showed signs of heat damage on alternator wire).  New interior panels were acquired but not yet covered with matching leather.
The list of open issues was very small.  The interior chrome needed refinishing, the speedometer needed replacing (it was metric without any Mph), needed to buy an electric fuel pump, hardtop frame had some rust-through spots at base, dash wood needed replace or new veneer, needed to find better looking heater knobs, new door lockset needed rekeying to match existing, new heater valve.  The car came with two steering wheels.  A wooden one installed and the original plastic one in a box.  If i wanted to use the big plastic steering wheel then I needed to fix the horn switch.
I was on the home stretch get car from welder, install gas tank, body prep, paint, electric, plumbing, interior, trim.  I found a shop in south atlanta that was going to do all the interior chrome on hourly rate and was going to just hand them the 30Lb bucket of parts interior parts.
That's when things went wrong.  Somebody stole the gas tank from dip-n-strip and the drivers side quarter panel is welded on wrong.  The opening for deck lid is 1/4" too narrow at back.  I was out of time and had to start packing for a move to Florida.  I have since acquired a good gas tank.  Otherwise  nothing else has been done.  The boxes have shuffled through three house without being opened and now sit in the attic - still unopened.  One of the seasts got damaged in moving and the leather shows a 6" scar where the dermis fibers can be seen below.
So that's the life story and current condition of car.  I was never building the car for collecting or showing.  The car was being built to be a brand new car and put on the road for 100,000 miles or more.  It was to be an everyday car that never needed anything more than routine maintenance.
I can't finish this car.  It will make me remember a pair of frame up Datsun roadster convertibles that a friend and I restored in college.  I still deeply regret selling my 2000 solex.  Best car I ever owned.  I go misty eyed just thinking about it.  I'll never live with myself if I finish this car and then sell it off.  I need to either sell it as an unfinished project  or part it out.
What would you do?
Title: Re: I need help. I don't know whether to sell car or push into ocean & sell parts
Post by: Ulf on October 24, 2012, 19:11:24
If it comes down to money, it's probably worth more in parts than as a complete restoration project, but then again you'll have the hassle of selling all the little items one by one on eBay with shipping etc. rather than getting rid of the whole lot in one go...
It seems like the only two things that are wrong are some welding and the tear in the seat, is that really enough to put you completely off a full restoration? I know that there are probably a lot of other factors that come into play here, but you might start to love the car again once you start fiddling and see progress. If you have held onto the car for 23 years and moved the parts 3 times, you must be emotionally attached to it somehow ;-)
Best wishes
Ulf
Post by: Garry on October 24, 2012, 21:06:11
Sell it complete as Ulf said the time and effort in selling it as parts is great and if you don't have the time to put it all back together then you wont have the time to sell all the parts either and it will be come a burden with time and effort.
Post by: Flyair on October 24, 2012, 21:57:03
Quite frankly, I wouldn't mind having a problem like that. it seems to me that you are 99% done with the restoration and two important, but eventually minor issues hold you off from getting things done.
by the fact of describing your story in such a complete and detailed way you give a proof that this is an emotional question for you and that your Pagoda is part of your household, if not your family :).
I hope that soon you will share with us some pictures of your shiny Pagoda reborn from ashes, or at least reborn from dusts ;D
Post by: w113dude on October 24, 2012, 22:19:30
As it's been said, it's a money issue selling the whole car is a lot easier than parting in addition will take much longer, the choices are fast selling as a whole project for less or parting out for a bit more and but will take longer.
Either way good luck.
Post by: mdsalemi on October 24, 2012, 23:25:15
Swamp,
Is money an issue?  It isn't always.  While many of us are not that wealthy, or liquid, as it were--there are plenty that can spend the money to fix this car up.  The remaining issues are extremely minor and can be done by any number of qualified and experienced people.  If you can afford to make it right, and want to then enjoy the car--do so.
If there is negative emotion here, sell it as a ready to complete project.  There's plenty of market for it.  Understand you won't get complete car pricing.
Do not attempt to part it out and sell it in pieces.  It's far more work than you imagine.
Post by: swampdog on October 25, 2012, 17:03:52
Thanks for your help.  It has added some clarity but not quite answered the core question.  I still need to figure out what is a fair price for "ready to complete" restoration.
Finishing it is not an option.  I was going to finish it and give it to my daughter for her high school graduation.  She doesn't want it because it looks like a retiree car and mom doesn't think it is safe enough.  The emotional attachment was to a previous frame up restoration of a Datsun 2000 Solex.  I sold the car in my early twenties to go on a cross country camping adventure and never forgave myself.  This car was the consolation prize when I came back home.  I did drive it for a few years before starting the restoration.  It was your basic 70,000 mile wifey car.  It was in about same shape as the ones going for $20k-30K now.  If I finish it then I might get attached and I'd rather not.  I can't drive it and nobody in family wants it.
As regards parts.  I would not bother selling any of the stuff that isn't easy.  I would sell the new in box stuff like lights, weatherstripping, top, wheels, etc.  Then the big ticket items like chrome, top frame, injector, steering wheels would go into attic with a long term ebay ad.  If the aluminum skins are worth anything then they could go into attic too.  Dump the rebuilt long block on craiglist for 1/2 price and call a junkyard to come haul away the rest.  all the glass, dash metal, radiators, wiring harness, instrument cluster stuff would just go in the trash.  it's just a question of which path generates the most money without too much work.
so, roughly speaking,  in ballpark terms,
how much is a ready to complete 230SL worth?  and what things would need to be specifically understood between buyer and seller so that both get a satisfactory transaction?
also - it has two steering wheels.  the original plastic one and a wooden one.  the wooden ones appear to sell for a few thousand on ebay.  Does it affect "kit car" price if I only include one steering wheel?
Post by: J. Huber on October 25, 2012, 17:45:15
How about some pictures? It sounds to me like, parts-wise you have a decent situation. Car-wise it sounds like a mess? (suggested price removed because I have no idea! but think its lower than you hope). Before you put out a hit-man on me, anybody else see a quicker way to unload it? I am leaning toward parting it.
Post by: stickandrudderman on October 25, 2012, 20:05:18
If you can strike a good deal with a professional restorer, that is a price that you both think is fair, I'd say that would be the better option.
I single transaction, nice and clean, the restorer knows exactly what he's getting and indeed getting into, another car is preserved and somebody someday gets a car that they will enjoy.
If you were in the UK and it was a RHD car I'd be offering max £5000 for it and figure on spending maybe £20000 turning it into a £35000 car so that might give you some idea of where you're at.
Post by: swampdog on October 25, 2012, 21:27:15
that's kind of what I'm thinking.  It's a waste of time trying to keep it whole.
Everybody is going to low ball it.  Why would I sell a car for £5000 when the new grille alone is being listed on ebay for £2000?  all i have to do is sell the grill, bumpers, and top frames to come out ahead.
Post by: mdsalemi on October 25, 2012, 23:04:42
Swampdog, once you start listing parts, negotiating prices, shipping, dealing with all that myriad stuff--you've bought yourself a job and a project.  As I understand it, you want to get rid of a project, not take a new one on.  Then, the complaints might start coming in--and you have to deal with all that as well.  Just ask the people here who have done a lot of parts sales--by eBay or other means.  It's work, and a lot of it.  No means of promotion comes quick, easy or cheap either.  If you want to wash your hands of the project in an easy sale, it will not be at top dollar--or pound for that matter.
Kind of reminds me of the sign at the mechanics: We can do your work CHEAP, FAST, or GREAT.  Pick any two.  ;)
Post by: 69280sl on October 26, 2012, 01:01:45
If you are guaging the value of used pagoda parts by that of Nardi steering wheels, you may be disappointed. I watch these on eBay and the only ones I have seen at over one thousand are NOS wheels for the 300sl.
If you can afford to have someone finish the project and sell it as a restored car you will be better off financially and i believe emotionally. Lots of pride and satisfaction in making a silk purse out of a sows ear.
Gus
Post by: glenn on October 26, 2012, 02:42:48
Where in Florida??     And how much????
Post by: Cees Klumper on October 26, 2012, 10:14:58
Like Glenn I was thinking: "I will need a project car at some point here in the Keys, what about now?" But then reason came back ...
Post by: swampdog on October 26, 2012, 12:53:36
Fort myers.  I don't know how much.  that's why I came here.
I just assumed that nobody would want to own an old worn out car. As such, I figured Pagodas were either already restored or bought to be restored.  That line of thinking caused me to place a monetary value on restoration work already completed and parts already acquired.
I realize now that my thinking was flawed.  Pagodas are the same as used boats on ebay.  A shiny piece of costume jewelry still sells for more than a dusty nugget.  Most people assume that under the dust is rust and those who know better are looking for a steal.
I should probably just take a few days and throw a lacquer yard job on the car.  When in rome, do as the romans do.
Post by: w113dude on October 26, 2012, 15:59:25
Why don't you put some pictures of the project on this forum you may find an offer that may work, without seeing anything it's hard to know what we're taking about and you may get an offer, I for one may be interested.
Post by: Sonia on October 27, 2012, 08:48:08
think for a second...
if you push your stuff to the ocean, what parts would you have for sale? maybe car keys….
so I gather that your problem is located elsewhere.
Would you like to talk about it? ???
Post by: swampdog on October 27, 2012, 12:49:48
the car, except for an unpainted shell & drivetrain, is in boxes in the attic.  most of which is new or rebuilt.
Post by: mdsalemi on October 27, 2012, 13:39:48
I don't know about you guys, but I'm tiring of this thread.
Based upon the information Swamp dog presents, the first move should have been some photos.  So far, lots of chit chat and no photos.  Others have asked, and just talk comes back.  Swampdog, post photos please or just give it up and put it up for sale as a lot on eBay.  I don't think anyone in their right mind would buy anything without photos or personal inspection.
Post by: Flyair on October 27, 2012, 14:04:12
Michael,
you are being too concrete and demanding.  ;D
I think that Sonia has the point. The problem is elsewhere: the  title of the thread starts with: "I need help…"
Maybe Swampdog needs help to be pushed into the ocean??? Cold water does miracles as doctor Prisnitz advised... ;D ;D ;D
Post by: swampdog on October 27, 2012, 16:24:14
so i haul all the stuff out of attic and take pictures.  great.  now you have pictures of 40-50 boxes.
I don't see how pictures of boxes makes any difference.  the body shell is undeneath a pile of shopvac hoses, extension cords, fertilizer spreaders, saws, blankets, misc boxes ... even looks like a portable A/C on the back.  the interior space has more vac parts, a weed whacker, a couple boxes of old plumbing parts, a bunch of compressor hoses, some snorkel stuff, and .. a cooler?  on top of the hardtop is an assortment of 4' heatshrink tubing and some rolls of veneer.  I think the trunk is full of canoeing lifejackets & stuff.  We never really canoed again after leaving atlanta so it was never unpacked.
and you want pictures?  pictures ... of what?  boxes?  does it matter to you if the boxes are neatly arranged for the picture?  would it be okay if I took pictures of some other boxes that are also equally square on the outside?
It is a frame up restoration.  maybe in MBZ world that is the wrong terminology and you can tell me the german name for it.
the car was completely dismantled until all that is left is a 100-150KG unibody pan with stamped in frame rails,
(I also left the windscreen, firewall, floorpan, ragtop compartment, rear wheel wells, and tail section)
the unibody pan is them put on a giant shish-k-bob thing and spun around 360 degrees while being sandblasted.
other than dip and strip this is the only way I know of to get guaranteed 100% rust free restoration.  So surely you are familiar?
the pan is appropriately undercoated and underpainted while all areas are accessible
new sheetmetal is welded on - sidewall, fenders, door jambs, rockers, quarters, nose, etc.
drivetrain with a bare long block engine is installed (to avoid scratching engine compartment later)
at this point time ran out and I had to put project away.  that was 17 years ago.
it has been inside dry garage taking up space ever since.
that's the picture you want.
an new car shell stripped to the bone with a bare long block engine.
why do you need that picture?
don't you already know what that looks like?
Post by: Neil Thompson on October 27, 2012, 17:12:09
You appear very aggressive Swampdog, your friends on the Forum are trying to help, if you want to sell it tell them how much you want for it, otherwise put it on an auction site as suggested or keep it.
Post by: mdsalemi on October 27, 2012, 17:21:38
Well, Swampdog, good luck.  You asked for help from a world wide group of experts.  They offered it.  One of the first things they asked for is photos.  I don't want photos as I already have a car and don't need another.  But anyone interested--and there are plenty I'm sure--will want more details.
You will NEVER be able to sell a hidden car shell, and myriad boxes all over the place, without some photos, or a personal visit.  The personal visit will come from locals, or someone interested enough (perhaps from photos?) to journey to see you and what you have.  Lots of postings here won't cut it.  But you do not have to believe me.  You'll find out on your own.  If you can't provide photos, an accurate comprehensive list of parts, or at least for most of them, might entice someone to get on a plane and visit.  But that's an investment not many are willing to take unless they know what they are coming to see.
In the time it has taken you to make this listing and follow up posts, you could have spent a few moments with the camera in your phone, or any cheap digital camera, and taken some photos of not boxes, but parts in the boxes--or compiled a list of parts in detail.  Do I really have to say that?
How to do it w/o photos:
"huge box of Pagoda 113 parts; included to my knowledge are complete L&R tail lamp assemblies, including inner and outer components, new; complete L&R headlight doors, early style, new.  Re-plated chrome grill bezel, including new anodized screens L&R, and a used, but perfectly acceptable grill star.  There are some smaller boxes of miscellaneous electrical parts, new; and some bags of fasteners with part numbers, but I don't know what it they are for.  This is only one box of 10 others I have which I think are all the parts to re-assemble a Pagoda"
How not to do it w/o photos:
"Many boxes of Pagoda parts.  Up in my attic."
You are going to have to put some effort in the process--not here on this forum, but in your attic.  If not, you will only attract tire kickers or locals.  Maybe that will work for you--I hope so!  Best of luck in your quest to extricated yourself from this situation.  Everyone is here to help anyone who comes.  But if you are not taking the advice of the people who are trying to help, we cannot be of much help I'm afraid.  So, it is in that spirit that I truly say I wish you the best of luck.
Post by: swampdog on October 27, 2012, 19:09:03
i'm not trying to get offers.  I get 2-3 a year just by leaving the garage door open.
I always politely say "no" right after they ask "would you be interested in selling it?"
this year I've decided to say "yes" and get rid of the thing.
i want to know a fair price range.
fair price - not premium price & not steal of the week
range.  - not an exact amount.
as regards what is in the attic.
everything needed to finish the project.  in 1994 i had $1500 left to spend.
the diamont paint is going to be sour, the continental radials dryrotted, & maybe the ragrtop window yellow from age.
none of the parts have been out of their boxes since purchased.
there is a 15Kg bucket of interior chrome parts that needs to be sent out
That plus $2500-$5000usd should be a generously safe budget for all remaining parts to result in a like new pagoda.
Post by: Garry on October 27, 2012, 21:32:12
Last year I had a look at a car that the owner has dismantled and done exactly what you had done, new bonnet, new panels for everywhere new chrome etc etc etc.  Put it all away 15 years ago and finally decided that the project of putting al the new parts back together was too much for him so he decided to sell it.
He was a Barrister and Solicitor and in fact he was a Queens Council so at the top of his profession and a very smart guy you would think.  well I flew to Perth Western Australia, 5 hours flight time to see this parts car and when I got there I spent five minutes looking at his pile of old 'new' 15 year old parts and caught a taxi back to the airport and went home.
Every item had rust, all the 'new chrome was pitted just sitting there, All the 'new' rubbers were stiff and perished, everything was in boxes, nothing labeled or cataloged, every nut and bolt in one box together, every screw in another and so it went on.
15 years ago it might have been worth the $18000 he was asking for it and you had a chance to properly catalogue the parts and group them but due to his lack of foresight and maybe some laziness thrown in as well, most of it was a heap of junk suitable for pushing in the ocean as swanpdog has suggested with his car that has been sitting there 17? years in bits.
My lesson, never ever ever ever go travel a long distance to look at something with out first seeing some detailed photos as the word of a Queens Council or anyone else for that matter is not worth diddly squit.
Whats it worth, $5000- $10,000 if what you say is true, but you are not going to advertise it on this forum unless you are a full member as that is a requirement for advertising "for sale" here.
And, you will need some photos which is something you don't appear to want to do so what I suggest is that you open your garage some more and wait for all those that go by that want to buy it to make you an offer that you are happy to accept, or of course put it all back together and only then have to sell one big part instead of lots of small parts. ;)
Post by: GGR on October 27, 2012, 22:01:51
The bad news is that one never recoup the money of a top restoration on these cars. Best deal on a Pagoda is to pay $45.000 for a car that costed $70.000 to restore. In your case, you already did a good part of the expense, but you're selling a project in boxes. You won't sell it much in that condition. Your best bet is to part it. But recouping part of the money is going to take time and work.
Hopefully, when you will be taking the parts out of the boxes, you will remember all the work and time that went through them and you will then decide to restore the car.
Post by: swampdog on October 27, 2012, 22:17:19
yeah, that's what i think too.  If I have to catalog all the parts in order to sell the car then I may as well just sell the parts.  They're worth more than the car.  I'll just shove the rest into the ocean and all the other pagoda just got a little bit more unique.
Post by: Neil Thompson on October 27, 2012, 22:58:43
Garry, wise words as I'd expect from you.
Swampdog, the people walking past your garage aren't as likely to be as strong a bidder as these guys u've asked the question of! Why, why aren't you listening?
Neil
Post by: swampdog on October 28, 2012, 00:20:58
Neil
It was never a matter of bidding.  Just fair market value.  I live in a waterfront neighborhood in southwest florida.  most of the snowbirds have million dollar homes with a big boat docked in the backyard.  All of which just sits there doing nothing for 10 months out of every year so that they have a winter vacation home.  The mercedes convertible would just be another toy in the garage for them.  like buying another jetski for the kids.
what I'm hearing is a fair market value around 10K.  that's just not even close to being worth the effort of having to unpack and inventory all the parts at one time.  I can call the junkman and have my garage empty in a day.  then I can take my time cleaning out the store room and attic.  it's a win-win.
Post by: GGR on October 28, 2012, 02:40:24
If your shell is not rotten, or has been repaired properly apart from that quarter panel it may be worth some money and interest someone restoring a rotten Pagoda.
Post by: Garry on October 28, 2012, 04:58:51
At best you may get $15k but now you have mentioned that it is near the beach and that should get alarm bells ringing given its been sitting 17 years.
But I am starting to think this whole post is a troll.
Post by: hauser on October 28, 2012, 06:01:57
You've sat on it this long why not finish what you started?
Post by: kampala on October 28, 2012, 07:31:22
Something doesn't smell right.  I'm with Garry ... this might be just entertainment.
By now a few photos could have been posted ... and 4 offers would have been sent over by PM.  Well worth the price of admission to be able to post for sale as full member.   something's fishy in Florida.
Post by: JamesL on October 28, 2012, 07:56:38
As you can buy a running car in the US in the $20,000 bracket, have no work and know what is operative and what is not, where needs attention and what does not, any price you get would do very well to push half that
Dealer will want a margin AFTER the rebuild/make it go process and an individual - other than a self restorer - will be in a similar position excluding the margin
Either way, other thah foot traffic past your yard, I'm afraid some photos - hell, even of the shell and VIN plate - are going to be needed!
Post by: swampdog on October 28, 2012, 11:01:51
I have arthritis now.  If my daughter was excited about the style or interested in mechanics then it might have been worth bearing the pains.
Post by: Garry on October 28, 2012, 11:09:43
Come on swampdog,  34 postings on the subject now, time for just one photo of the VIN plate or even just the shell to ensure it is all real ;D ;D
Post by: swampdog on October 28, 2012, 12:19:05
i guess I have wasted enough of your time so I may as well waste some of mine in return.
it seems obvious at this time that a whole Pagoda in any condition is worth much less than the sum of the parts.
what looks like rust behind engine is sanding debris.  There is a sanding machine next to car at that location.  the sheet metal all came from MBZ with black primer and was undercoated with PPG AE (MB beige color) prior to welding.  this was the original color with chocolate hardtop and hubcaps.  you can see some of the overspray and drip on the quarter panel.  exterior weld joints all have surfacerust.  sandblasted upper shell was treated and primed with PPG DP401 type epoxy primer.  it will take a couple hours with phospo acid and a wire brush to clean up surface rust.  you can see some on corner of windshield frame.  fairly typical.  the bad corner weld is the entire length of seam.  the top gap is correct.  the gap narrows by 1/4" from front corner to rear.  the quarter panel includes weld to wheel well that are difficult to reach.  in order to make a structurally perfect repair the quarter may need replacing.  the pile of boxes is one of two in a spare bedroom.  it would include rubber, leather, softops, electrical, etc.  third pile in attic not climate controlled.  chrome, glass, wheels, etc.  firewall padding in trunk might be the old pad kept to help with future fitting.  The new pad was cut slightly different.  If the one in picture was new pad then i would expect other items in trunk to have equal dust.  the uncovered doorpanels can also be seen in trunk.  there was a problem with stitching on door leather.  Did not match original.  needed to be stitched differently.  I don't think it was ever fixed. that's about it for all the meaningful comments i can see.
Post by: swampdog on October 28, 2012, 12:29:52
two more pics.  my browser or account has limit of four per post.
Post by: w113dude on October 28, 2012, 13:30:51
I'm in a process of finishing a project that was in similar condition when started, to get this car in driving condition it will need 200 to 300 hours of labor depending on quality required. in my estimate as a package if you can get $10K or something close you should take it if not part it out, it'll take a few days to get all the boxes opened and photographed then boxing and shipping, in my estimate it'll bring $13k or a bit more.
Post by: swampdog on October 28, 2012, 14:50:22
that was my estimate - 6 manweeks + 3500 parts
if it was a 280 then it would be worth fixing up.
as a 230 i'm 95% sure from this thread that it is worth much more as parts.
Post by: J. Huber on October 28, 2012, 14:57:11
if it was a 280 then it would be worth fixing up...
Ok -- now you are starting to get on my nerves  ::)
Thank you for the pictures. I think its time to start dusting.
Post by: Neil Thompson on October 28, 2012, 17:10:30
Well Swampdog, you've stirred some interest now! If you did this at the start I would guess the offers would be flying in by now. Good Luck
Post by: swampdog on October 28, 2012, 18:47:35
never wanted offers just wanted a straight answer.
two pages later - a 230sl is worth more as parts than car.
what was so hard about saying that on page 1?
Post by: Garry on October 28, 2012, 20:10:12
Well  done swampdog, finally some pix.
Now back to your original posting where you asked
Quote"
What would you do? "
Unquote
From all the posts you will see that it may be more profitable to part it out but on this forum that would be sacrilege.  What you can also gather from these postings is that there are many that would be interested in buying it as a whole.  The third thing you can see from the postings is that the time to finish the job will be pretty much the same as all the effort required to sell off the individual parts.
SO if its money you want then parting appears to be the way, but, you said the very words that will come to haunt you in later life and that is that you will never be able to live with yourself if you finish and then sell. I don't think it will be any different seeing it go in bits as well. That to me would be the most awful feeling that I nearly got it all together and now I am just flogging off all the parts that would have allowed me or someone else finish the project. Your vision goes out the door in an ever smaller pile of bits. The perfect mental anguish of a defeated man.
Your last question was "what would you do"
My answer, if you need the money but clearly from some of your postings you don't have the time, then sell it as a project.However, life is not always about money and sometimes its more important to achieve some personal satisfaction or know that you have done what is the correct thing even though you could get more "money".
I am sure there are plenty here that can help you one way or another. To either put it all together and enjoy the satisfaction of finishing the job you started and enjoy your labours with many a peasant sunday drive or if the 'money is driving this need' sell it as a whole to someone that will get it all together and one day come over and show you what a wonderful car it turns out to be.
And last but not least, the thing that is so hard for everyone on this Forum to say is 'part out", we are all here to help each other restore and revive these wonderful examples of '60s vehicles. Other than a Vendor, we are not here to try to make money by selling parts
Post by: swampdog on October 29, 2012, 18:23:24
I called the guy who wanted to buy it last week and told him that I really appreciated his interest but that I was just going to part it out.  He asked if he could bring a friend and look at it before I started cutting it up and shipping it out.  His friend was a mercedes specialist or something.
He said it was a 250SL based on year and serial numbers.
He also said the quarter panel was going have to be removed and replaced.
I got the feeling they were excited but did not want to say so.
How much difference does 230 vs 250 make in money?
does it make the thing worth more as a car than as parts?
Post by: waqas on October 29, 2012, 20:00:58
He said it was a 250SL based on year and serial numbers. I got the feeling they were excited but did not want to say so.
As far as I understand, there is no discernible difference, especially in the present condition of the car.
However, I think you may be severely under-valuing a 230 SL. I own two myself, and they are in different stages
of [very long-term] restoration. I've rarely if ever questioned my choice of restoring a 230 SL instead of a 280 SL.
If anything, this type of discussion only renews my desire to keep more 230 SLs on the road.
By my estimate, the value of the car parts in this condition is at most 20% higher than the value of the sum total.
BUT that comes with a huge caveat: the value is only higher if you're able to find a buyer willing to pay for
the peak value of each part. For some parts, this will be easier to achieve (e.g. bumpers, grille, chrome trim, etc).
For most of the parts, you'll be fighting a war of attrition. If you happen to find the right buyer for each low-demand
part at the right time, then you're set. But that is a big IF. My guess is you will spend the next year or more trying to yield
the peak value of all the parts, and most parts will not yield near their value. When all is said and done, you'll eventually
sell those difficult-to-sell parts at big discounts just to get rid of them. You'll likely end up breaking close to even with
what you might have gotten for the whole car up-front. [ You're actually better-off selling the whole car now and then
immediately re-investing the proceeds into the stock market! ]
The mantra that a car is worth more in parts only yields results for those who have an unlimited amount of time and
patience toward this endeavor (such as salvage yards, parts houses, etc).
Garry makes some really excellent points:
Quote
...life is not always about money and sometimes its more important to achieve some personal satisfaction or know that
...sell it as a whole to someone that will get it all together and one day come over and show you what a wonderful car
it turns out to be.
...we are all here to help each other restore and revive these wonderful examples of '60s vehicles.
Yes, if you part it out, there is a possibility that you'll make a very marginal amount of money more than keeping the car
complete. But there will be one less example of this car on the road today. And that will be the real legacy of such an action.
Post by: swampdog on October 29, 2012, 21:55:51
my engine never even had oil put in it.  it still turns by hand and you can still eat off the cam towers.
not a speck of dust or rust inside.  a handful of SS bolts to replace the iron ones and it's good to go.
it was rebuilt by the top guru in atlanta with six month waiting list.
I have reciept to confirm a complete rebuild with all new guts.
the injector pump still has the dealer label on it.  i have a new grill, four new alloys, new headlamps with trim, new tail lamps, and a box of new rubber with everything except windshield.
maybe I am not understanding something.  if i dumped just these parts on ebay for half price it would be right around $10K
why is it difficult to part out?
Post by: waqas on October 29, 2012, 23:13:02
Sounds like your car is worth a lot more than simply a "parts car." My points still stand, as I was speaking in
relative terms between parts vs. whole car. All you're saying is that the value of the entire collection is higher,
regardless of the method you use.
It also seems like your restoration is far closer to completion than I thought-- almost like a "model kit"--
and I'd wager most of us who are [or have in the past been] mired in our own restorations would jump at
the chance to simply "assemble" the kit (caveats and all). Based on all the restored and new parts you mention,
the [properly] completed car will probably fetch top dollar.
At this point, I think any discussions about absolute value are fairly useless without detailed lists / condition etc.
Post by: Paul & Dolly on October 30, 2012, 00:23:33
[/quote]
If you have the VIN Plate or number,  then you can tell if it is a 230 or 250 SL, also the Engine should have an identifiable Casting mark.
Paul
