W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: johnnymack on January 20, 2013, 19:11:47
I've just finished doing the short out on the rheostat , as described in the tech manual, the fix blew the fuse. Not sure what I did wrong.? Has any one else done this?
recheck the wiring connectors under the dash, or the bulb sockets touching the metal somewhere will cause short too.
Hi Johnny, I did this as per the manual and didn't have any trouble. I also resurrected the headlight flasher option on the indicator stalk, as per the manual, successfully.
cheers
Rutger K
Yes Johnny
I have also done it and had no problems
Frank
Thanks for the input, I have more time to get it. Probably wont be driving her til may .
I am also willing to bypass the rheostat.
I just want to be sure I will work on the good connector.
I have opened the one on the middle of the plate (between a brown connector and a round one), but the colors of the cables doesn't seem to match the description on the tech manual. in particular, there are two cables arriving on the n° 5 pin.
Could anybody give me more details in order to get the good connector ?
I followed directions and I got them to work, hurray!! Small victory
Finally, it is also OK for me.
The right connector is the closest to the driver.
On my 71 280SL, contrary to the instructions, the connector is a brown Bakelite box, and the cover is held by 3 screws.
But the heater levers lights don't work (I replaced the levers and the lights recently, but I could have done something wrong in putting them back in place).
