W113 Pagoda SL Group => Electrical and Instruments => Topic started by: JimVillers on March 01, 2013, 15:53:04
I have problem with my driver side tail light. It has less than one volt at the tail light connector; the passenger side tail light works fine.
Does anyone know the location of connector #46 on the wiring diagram? I have traced the wires into the soft top well (which I have not looked in because I have the hard top on and I haven't looked under the dash because of the under dash cover. The voltage is normal at the fuse.
There is a connector block just above the kick panel by the hood(bonnet) release lever.
This applies to my RHD car so assume that it will be similar on a LHD car but opposite side.
This takes feed to the rear lights etc.
