W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: hs on March 21, 2013, 13:00:46
is it possible to use a chain targeted at a 280 engine used on a 230 engine
The chains for the 230, 250 and 280 are all the same.
Partnumber A0009974694
Yes all the 230, 250 280 SE, SL straight 6 cyl mechanically fuel injected engines use the same 134 link doble row timing chain. The carbureted 230, 250, 280 engines use a shorter chain.
Thanks Joe. You're right, i only looked at chains for the injected models.
To make things clear.
Partnumber A0009974694: chain for the 230, 250 and 280 injected engines.
Partnumber A0009977094: chain for the 230, 250 and 280 carbureted engines.
