W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Stuttgart68 on April 01, 2013, 23:56:38
Title: Oil leaking
Post by: Stuttgart68 on April 01, 2013, 23:56:38
Hi There,
Last month I recognized some leaking under the engine block around the area of the oil pan.
Now I would like to address a few question to this community:
I suspect it comes from a worn oil pan gasket, or the screws of the oil pan are not properly tighten?
It is mainly after I am returning back from a trip and the car has been parked in the garage.
Can the car still be driven? I hope that any workshop can work on this issue as I have no specialized MB garage here nearby, unless you go to the Mercedes Benz dealer....
Enzo
Title: Re: Oil leaking
Post by: Ron on April 03, 2013, 03:26:29
Hi Enzo, there are others on this thread with a lot more experience than me, but I'll throw in my input to start you on your quest.  My engine and its accessories had many leaks.  I had oil leaks that showed up on the pan bottom from: valve cover gasket, hose fitting on top of oil filter, and injection pump governor housing.  The main leak was was from a poorly installed rear main seal.
To find all these, I clipped on rags at various places, cleaned leaked oil away and ran car.  When rag turned up wet with oil, I had my leak.
The rear main was a pain.  (I purchased my car with engine out, and PO claimed it was "rebuilt".  It was, but a poor job, and once in the car, it's problems showed up.)  For the rear main, the oil came dripped from the flywheel housing, the lowest spot and a bit at rear of pan.  To fix, you'll have to remove the engine, then the crank and replace both halves of the rear seal.  At the same time, I tore down the whole engine and replaced all the things that should have been replaced by the PO's machine shop.  Back in the car, the engine runs wonderful, but I still have leaks to fix (trans and power steering box), and I'm not sure that the rear main on the engine is truly fixed.
There is no gasket for the pan, use the best sealer you can find if you remove it.
If your car did not leak before your trip, I would guess it is not leaking from the pan or rear seal.  Something more simple I would hope.
Ron
Post by: Kayvan on April 03, 2013, 04:02:54
Oil pans are easily bent and hammers are used to flatten...
New like pan is $800 per classic center
Make sure ur pan is flat and true
Post by: georgem on April 03, 2013, 04:26:51
Another source of leaks comes through studs srewed into the engine block that haven`t had thread sealer applied (effectively) I currently have a gusher from one of the studs at the bottom of the block that holds the alternator bracket on.
Good hunting
