W113 Pagoda SL Group => General Discussion => Topic started by: Flyair on May 19, 2013, 08:39:16
Having read this morning the break-down story brought by Intex in another post, I thought it would be interesting to share our respective stories about break-downs of our venerable Pagodas.
I suggest that we do not describe that mush what went wrong but what were the circumstances and consequences, if any…
In my case, as my Pagoda is in the final stage of restoration after being brought from the States, there is not much to say. In other words, the future will - no doubt - reserve some surprises… Nevertheless, for a start …
I had a little mishap when my Pagoda came to Poland in a container and the custom officers waited to see her. The port handler moved the car out, the customs guys did their work and at the end I wanted to fire it up and leave…. shamefully, no sign of life… the fuel was there, but obviously the battery was dead. Nothing special and I guess quite common after a long trip by sea, but my first contact with the car in Poland was not as I hoped it would be… ;)
I had owned my 280SL for about 7 years without a break down then one day driving on the city freeway80km from home it just stopped. Pulled over to the emergency lane and called the Auto Club and whilst waiting, who should turn up but the previous owner who I had not seen from the day I purchased it. It was a minor electrical fault a wire had dislodged from the coil and I was soon on my way. The only day it stopped on me in the ten years I had it and the PO who I had not seen since purchase or since then goes by. What a coincidence.
Sounds like a Twilight zone episode! :)
So I tried to think of an 'unusual circumstances breakdown' but unsuccessfully so. In fact, although I've had a few instances where the car would not start due to a loose contact or some such, and twice where it would stall if I would not stay on the accellerator (due to an incorrect distributor having been fitted by a PO, Van Dijk discovered after extensive diagnostics), I've always been able to get it going and never needed a tow (touch wood ...). I did once have one of the brake discs overheat because the brake hose was restricted. But even then, after cooling, I was able to resume the drive. On my other cars, let's see, in chronological order from 1978 on ...
Jaguar XJ 6: brake failure
Triumph Spitfire: breakdowns due to broken alternator (seized bearing) and broken valve spring
Ford Pinto: engine fire
Ford Mustang: coolant leak
Audi 80: dead battery
Alfa Romeo: turbo pipe came undone
Fiat coupe: blown engine, totally blown
Volvo C70: broken alternator, no warning light: dead battery
El Camino: coolant leak
The Pinto was by far the most unusual, in that the fire happened on my way back from work, on a Friday afternoon, after just having gotten off I-95 (South Florida) at the Boca Raton exit. Flames underhood, another driver managed to put it out relatively quickly. But what happened next was the kicker: as the fire drew the usual emergency helpers (ambulance, fire truck, police) after it was over the police officer kindly offered to drive me to my home, two miles east. However, he was young and regulations mandated he frisk me for weapons before allowing me into the squad car. So here I am, off side of road, in my dark blue suit, Bally briefcase in hand, next to my stranded white Pinto, being frisked by a police officer. I was only praying none of my friends or neighbours would spot me with my hands over my head ...
Pretty funny Cees, reminded me of my own barbecue. No drama with my Pagoda, but back when I was in college in Boston i was "learning" to maintain my 1971 VW Beetle. I adjusted the valves, and was surprised at how far out they were. I figured "Wow, the car will run GREAT now that I have the valves in order". Wrong. I set out for school, running late, and the car was running terribly. But I had to get to class, so I just ran it with terrible stumble and backfire. About two miles out I smelled that unmistakable smell of red hot metal and rubber. Pulled over in a residential neighborhood and saw that the tailpipes were glowing and there was significant smoke in the engine compartment. Went to the closest house to call the fire department.
Guy answers the door with hand behind his back. I tell him I think my car is going to catch fire. He shows me his handgun and invites me inside, where he calls in the emergency. From his living room window we watched the car ignite Could not have been more than 2 minutes from putting the call in that the engine company arrived, broke all the windows, and filled the car with foam. Totaled.
Later I figured out that I had set at least one cylinder's valves 180 degrees off. Using the muffler as a combustion chamber is a bad idea.
Turns out the guy whose house I went to was the Chief of Boston's Fire Department!
Talk about young and dumb!
Greg
Wow Greg, what a story ... what made it really come to life was the handgun-behind-the-back .... somehow I picture it with the Fire Chief still in his housecoat. Sorry to hear about the Bug (here in France they have a very nice-sounding acronym: 'Cocinelle', or 'Ladybug'.
It is amazing how fast fires can spread and wreak havock. Ever since then, I always carry a fire extinguisher with me in both of my oldtimers.
Looking forward to hearing others' stories of unusual breakdown situations.
With the Pagoda the other day I hit a pothole and the car died instantly. Turns out that a wire got dislodged from the ignition module. I fiddled in that area little before and I must have pulled on the wire in the process making it prone to dislodging.
In 1987, I was a student and the proud owner of a rusted out Alfa 2000 GTV I had bought in a junkyard. I wanted to see how fast it could go so I took it over 200 km/h on the highway. This is when the oil pressure dropped and a rod went through the engine block right where the engine bracket was, taking it out in the process and causing the engine to drop on one side. I guess this is what we call "catastrophic failure". So here we were, my friend and me, hitchicking next to the car when an old man (to us) stopped and came out of his car with a rope. He explained to us he had sons our age doing the same kind of stupid things and he tied our car behind his. he said he was going to drive relatively fast to avoid being crashed into from behind. So here we were, at 130 km/h in tow 1,5 m behind the towing car, with no power brakes. I still wonder who from him or us was the crazyest. Anyway, we got out of the highway and back home safely.
Another day a friend called me telling me his Mini had gone electric. He was driving when the engine started revving as if in neutral. He stopped the car and tried starting it again. the starter would work but the engine would not engage. While putting in gear, the starter motor would move the car without the engine being engaged. On the Minis the flywheel is held to the crankshaft by one big bolt that had come loose. So the starter motor would engage the flywheel and the transmission when in gear, but not the engine. We repaired the car, which cought fire a few weeks later, unrelated to the previous issue.
In reading Garry's comment, it reminded me of a very similar problem that I encountered a few days before I traded my ill fated 250 SL for my 280 SL. I had been working late and came out to my car around 9:00pm and could not get it started. I called the auto club and since the dealer was closed, and it it probably would not look to have the car I was going to trade in towed to their shop, had it towed to my home which was about 10 miles from work (no flat beds in those days). After getting some light on things (it was pitch black in the parking lot and I had no flash light/torch) I discovered the coil wire was loose. Plugged it in and the engine fired right up. After the accident I had in the 250 a year prior, the car never really ever ran correctly and was in the shop for all manner of things, primarily electrical. That was the only time though that it actually couldn't get it to start and the car never actually quit on me. Moral of the story, always carry a flashlight :)
Does this count as a breakdown?
Last year (as you may know) I had my engine bay restored, and so good it looks too! On my way back from Manchester on the M62 I could feel that the car was performing better than expected, in fact a little too well! It appeared that going down hill I was braking heavily, rather than become worried, I began marvelling at the difference in performance having the engine cleaned up had made. I suspected nothing until a few miles later, when going up hill, I was still braking.
I was on a motorway (freeway for our US cousins) so I continued as long as I dare, but eventually realised that the car was over revving to the point I was uncomfortable for her health. I pulled onto the hard shoulder, switched off the engine and allowed to come to a graceful halt.
With trucks and cars pounding past at break neck (and for that matter Pagoda) speeds I called the breakdown truck. She was taken home and the next day I found that the tickover screw had vibrated off putting the accelerator on full.
The cost to fix the fault?... 30p (about 50c).
The cost of my stupidity for driving her on full acceleration? ... £2,000 (about $2600) as I then had to replace the brakes!
Testimony to he fact that these cars are cleverer than us (or me at least).
Mark.
My car has left me stranded only once. It was at my brothers house... as I pulled out of the driveway, I felt the shifter dis-engage as I moved from Park to Reverse and found I had no control over the transmission. The "unusual" (or should I mention "uncanny") part is that my brother had owned a transmission repair shop for 35 years and knew exactly what was up. The plastic clip/ring on the shift assembly had fallen off and was on the ground under the car. We snapped it in place and I drove the car home, picking up a replacement part the local MB dealer the next day.
I am glad that this thread has had so many visits and posts since created. One intermediate conclusion I can draw is that Pagoda seems like a very reliable car, and if a breakdown there was, it usually ended up in a minor fault or disfunction. It clearly appears that breakdowns concerned usually "the other cars" :D
Please keep it alive as I think that it also gives everybody a good sense how personal our rapport is towards these beautiful and rarely capricious ladies :)
Apart from a flat battery once, my Pagoda has never failed me yet (touch wood) - quite a change from the succession of British sports cars that I've owned over time - worst failure was when the brake pedal on my 67´Triumph Spitfire suddenly dropped onto the floor while I was doing 75 mph on the highway approaching a long line of slower cars ahead. Only thing to do was to drive on to the grass on the soft shoulder - still can´t forget the facial expression on these people when they were overtaken on the wrong side by a small red sports car flying by on the grass next to the highway before it eventually came to a halt. Could have gone seriously wrong though...
My TR6 caught fire behind the dash board once but I managed to put it out with a bottle of Lipton Ice Tea without even stopping as I was on my way to a job interview - guess I was a bit more reckless in those days.
I guess that since then you keep a bottle of that beverage in your car handy, as a compulsory equipment :D
Maybe you should maybe let the producer know about secondary application of that device ;D
Ulf
I can imagine the expression on your face going 75 mph without any brakes, I know it would scare the crap out of me, and probably not willing to drive for a while till color of my face came back to normal ;D
My contribution to this thread is the word 'Boccola' - Italian for bush, as in gear selector linkage bush. Mine disintegrated just outside Rome last summer but got great support and advice from people on this forumthat helped me get up and running again.
Full story here
http://www.sl113.org/forums/index.php?topic=17053.msg117751#msg117751 (http://www.sl113.org/forums/index.php?topic=17053.msg117751#msg117751)
and this is the offending 'Boccola'
I also had the gear shift lever come lose. Completely off as a matter of fact.
Since I have an automatic I put on the emergency break, put the wheel choch
behind the rear wheel then crawled under the car and put it in gear.
A little scary but it worked.
Bill! A little scary?
At least I hope you lay under the car in such as way that, should the car take off despite the e-brake and the wheel chock, it would not ron over you, just 'past' you! Good trick otherwise, but would have been better with someone applying all their force to the brake pedal on top of the other preventive measures...
So one more story on scary breakdowns, again in a Triumph Spitfire: a friend of mine and I went for a test drive on the highway. After having pushed it to around 70 MPH, just as we left the highway to head home, the car all of a sudden dropped to the right rear, and the chassis started scraping over the road surface. As we quickly came to a stop, the right rear wheel kept going, liberated and leaving us behind, bewildered. Turned out my friend had fitted his knock off wire wheel hubs on their respective wrong sides, not knowing they are uni-directional (like snow tires) so there is a right and a left hand hub. This to prevent wheels from accidentally spinning themselves free ... as happened to us, luckily not at 70 MPH on the highway ...
Cees
As a side question…. Who was seating on the right side? :D
I have had that exact problem several times over the years. The most recent one was after having an expensive transmission overhaul. I was some 30 miles from home about to enter traffic on US1 when I decided to select low since I thought I'd need considerable acceleration and at the time the kickdown function wasn't working. I selected low and felt the shifter go limp. The rollback got there fairly quickly and the transmission shop voluntarily picked up the entire tab. A much more amusing problem was a few weeks ago. I had just finished rebuilding the powersteering pump and the car was running beautifully before that job. I put the hoses back on, fill the system and was going to start it up to check for leaks. She made no attempt to start. I fiddled with it for two days when my neighbor who was helping me decided to look at the points. When he was trying to refit the distributor cap I saw the distributor move. We rotated it clockwise about 45 degrees and the engine started instantly and purred like a kitten. Apparently while removing the battery for better access I had moved the distributor which wasn't clamped as tight as it should have been.
Gerry
Well, I have been stranded 5 times in my Pagoda. Now 5 might sound like a lot but considering this is over 25 years and literally thousands of drives it is very minimal I'd say. (it would be interesting to know how many there actually have been...)
1. 1989. While parking, I pulled up too far into the perpendicular facing curb. Bent the crud out of the radiator. Be careful of this.
2. 1992. While coming home on a Sunday from San Diego to Santa Barbara, car overheated (majorly)-- this was pre-cell and being a Sunday evening nothing was open. I had to go for it -- making many stops to cool and add water when I could. I hit the stretch between Ventura and SB just hoping to limp to the finish line. Didn't make it. Blew the engine, car died and had to be towed the last 5 miles... Dang.
3. 1994. While trying to impress my beautiful bride-to-be, we took a ride, ironically from Santa Barbara down to Ventura. On the way home, car sputtered on the 101 and died on the off-ramp. What is it with the Ventura Highway? Would not start. This time, I called for a tow. Faulty points... If I only knew then, what I know now, I'd have probably been able to tinker with the points and get us home.
4. 1999. While getting a couple groceries, I came out and car would not start. You know, its embarrassing to have such a pretty car but have people watch you not get it started... Again points and plugs (but no clue).
5. 2010? While picking up my daughter from a friend's house, the car lights dimmed, then the everything went out. By now, I was a Pagoda Group junkie and thought, I can figure this one out. Checked connections to battery, checked starter, and every other thing I could do in the dark. Still confounded. Friend there had a battery charger -- that didn't help. Battery would charge then ran down really quickly... Had the car towed home and the next day figured it out. I had been detailing the engine compartment earlier that day and accidentally unplugged the wires to the voltage regulator. It is that important.
Thank goodness for AAA!
J
J
So J, do you think it's time to upgrade to electric ignition yet? ;D
While J meditates the merits of the 123 ignition, I just want to remark that his list of mishaps is impressive. Who says better? ;)
I am a big proponent of the 123 electronic ignition. When I first took delivery of my Pagoda, the points and plugs got fouled frequently caused (as J Huber has elegantly articulated) embarrassing moments. I have installed the 123...Awesome!
I frequently travel. After one trip, I couldn't wait to get home and drive the car. I returned home on a Friday around 9:30 PM. It was a bit late to go out to dinner so, I went out to get a pizza to go. Understand my excitement when I hopped in the car and fired up the "Old Boy". The car ran perfectly, to the restaurant. When I got back in the car and fired it up, no problem...However...half way home, the lights began to dim and the car was acting funny. As I pulled up to my drive way, and hit the turn signal, the car died...I immediately thought the battery. Thankfully, I drifted into the driveway and was off the street. I thought it best to shut the car down and let the car rest. After eating our pizza, I went out about 45 minutes later and tried to start the car...clickkkkkkkkkk...clickkkkkkkk. Yes, dead battery.
My story is not quite finished. Has anyone in this Forum asked their 5'1'', 105lb wife to help you push the car up the drive way into the garage? She was not a happy camper!
To close out, I went to Mercedes and bought a battery...all good!
My story is night quite finished. Has anyone in this Forum asked their 5'1'', 105lb wife to help you push the car up the drive way into the garage? She was not a happy camper!
At 105 LB she was keeping you company more than helping you push the car in. ;D
it seems that I can add one on my own: last Saturday I finally got the key for my Pagoda that was declared as nearly fully finished, fine-tuned etc. I say nearly finish as all the mechanic and body related items have been completed, and there are only a few things that require some more care. Anyway, the car drove well, the sound of the engine was music to my ear and everything seemed fine.
I had an invitation to participate in a vintage Mercedes gathering some 50 km (35 miles) away, so last Saturday I headed in that direction enjoying cloudless sky and green scenery of Warsaw suburbs.
As a part of the route happened to be a Freeway, I pushed the car a bit driving at about 135km/h (85m/h) and then, suddenly, the engine went to idle revs and there was no reaction from pressing the acceleration pedal.
Having stopped on the security sleeve, I tried to see what went wrong and soon was able to locate the culprit: one of the accelerator rods was moving free as its ball socket broke away from the ball. Unfortunately, it was the one that is deeply down under the collector on the right side of the engine.
I called the mechanic who worked on the car and he was only able to advise me to try fixing it by hand. He obviously warned me that it may not work as some force is necessary and the space is very limited, and that I should be careful not to touch the hot parts. With nearly 30oC (95oF) outside and after driving one hour you can imagine that waiting for the engine to cool down could last for ages. After some 45 min, using as protection the tool bag (original ;)), I started my unequal battle with the rod. Finally, after several attempts, I pushed it sufficiently well, so it moved again in place. I was first quite sure that it would break free again soon, but to my surprise, things held firmly, so I was able to join my colleagues in the last hour of the gathering and, later on, drive safely home.
Bottom line: I pleased to have fixed this stuff by myself, sadly at the expense of one nasty burn on my hand. I was also surprised that the replacement piece costs only 2.68 Euro at SLS, as I hoped that I repaired something more valuable that would be very costly to replace :D. Anyhow, it was amazing how a little, if not insignificant piece of metal can affect your life... ;D
And what was so unusual in this story? Well… it happened on... the first day I actually drove my complete and restored Pagoda for the first in Poland after bringing it here fro the US in 2009 and a lengthy renovation ...
Last Sunday I decided to take my car to the east end of town were every Sunday a gardening of old cars takes place. I knew that the week before I encountered issues with low idle and the car actually went to zero RPM when I shifted into gear and the car then stalled.
Anyway I had not driven the car for 8 days so I tarted to feel guilty ignoring her and so I chanced it by going out to this old car gathering anyway. Needless to say when I slowly pulled into the shopping centre at the east end of town in the middle of the chopping centre amounts all them old American cars my new found friend decided to stall. Repeated starts produced the same results. One fellow leaned over the car and in a comical way declared "I think my friend your nice car needs a bit of a tune up" .... I simply replayed "yes I know" ... Started the car again gently revved the throttle and shifted into gear and drove right back home again. ... Not such a happy moment ... I did not feel like sticking around :(
I'm happy to report Dan (Benz Dr) Took care of this minor issue today by correctly setting the linkage :) Thanks Dan!
Pretty easy fix. Someone opened the throttle valve too much and I had to turn the stop screw out about 3 full turns before I could feel the valve starting to grab. Since the engine was still warm, I left it open a bit more than what I would normally make this setting so that the throttle plate would still open when everything cooled down.
Once I made this adjustment, I had to reset the lenght of the throttle rod going to the air valve. The injection pump lever was opening before the air valve so this adjustment made both levers open at the same time. When I checked the idle mixture by opening the idle air screw, I saw that the idle mixture was too lean. A couple of clicks to the idle mixture knob and it purred like a kitten. The reason the engine was stalling was due to a very lean condition at idle.
Now we need to fix the kick down and modulator control which should make it run much better. Very nice car!
I had a dream... Dan - in his Benz Dr. Excellent Adventure - rather than just visiting certain places in the US, goes on a World tournée, visiting sites rich in Pagodas. At each site he cures all the needy cars and provides mental (or spiritual) rielief to their tourmented owners. No offence to other Pagoda's gurus, but we badly lack authorities in our dispersed herd ;)
( not sure who this guy is but he really wants me to go to Poland ) ;D
Stan, Great idea :) something similar to the idea I had ... see this thread Post #51 ----> http://www.sl113.org/forums/index.php?topic=18300.msg130346#msg130346
Once route 66 is done he could head north along the coastal highway 1 (101 is some cases) then turn back east around Portland, Oregon .... Stops could be arranged at strategic locations where Pagoda members can meet and pick his brains :) ... kinda like "Have Gun will travel" only in Dan's case it be "Made Pagoda issues my life's challenge for over 30 years ~ ready to share the most inner secrets" .... that be a fun gathering :)
Naturally we have to work out some sort of payback venture since we Canadians are not allowed to work or consult without the "Green Card"
yes ... yes I know it's only a dream ... still what a dream :)
What is meant by turn back east around Portland??? That would leave out the entire Vancouver, British Columbia contingent.
We could have a BBQ in the good Doctor's honour and I'm sure we could scrounge up at least 10 Pagodas.
How about a twist on the subject? How about an unusual circumstancs where my Padoda did NOT break down (but should have)?
September, 2006: ongoing runnability issues that just wouldn't go away. I thought I solved one of them, when changeover to Pertronix from Crane eliminated the "dying" while driving. Still had wildly unpredictable and erratic misfiring. What do do? Get in the car and drive on the highway to Chicago, of course, for the MBCA 50th Anniversary...240 miles.
It was stinking hot, and I was caught in stop and go traffic on I94 sandwiched in a rutty construction zone between gravel haulers and tractor trailers. Miraculously, perhaps by divine intervention, no misfire, no overheating, and just as important, no stones kicked up. I eventually get to the banquet hotel and in the parking lot, the misfiring returns big time.
The return home was not as eventful as getting there, but misfiring did happen with alarming regularity.
Several weeks later I change the fuel pump and come to find out that the power connectors that had been crimped on had failed. How any current got through those cruddy connectors is beyond me. By all rights the car should have died right in the middle of that construction zone. But, it held up.
Bonnyboy, we cannot expect him to cover the entire country can we now :) besides the brave Canadian fellows like yourself can venture a bit south and meet him when he turns back east around Portland ... this way he can take in Mount Rushmore as well :) in fact we can make or organize it as one of the meeting places :)
I might be in the middle of one!
Picked the car up from its annual service late Friday afternoon. It drove perfectly all weekend. It was a fabulous day on Sunday and I left it late to get down to the airport. Road deserted, roof down, sun sparkling on the sea and Gendarmes still snoozing after lunch. As good as it gets (other than the 'plane to London to go to work bit). Arrived at the Click & Park car park and found a "safe" parking space. No reverse gear. Must be operator error - tried again and again and again. Still no reverse gear. Much tooting from the world's most impatient people group queued behind me. I decided that reverse gear was unlikely to re-boot in my absence and so reverse pushed the car into a parking space. More tooting but no-one helps me push. Ran to the terminal; now very hot and composing the "For Sale" advertisement in my head.
Pause for calm reflection overnight, a quick search in the Technical Manual and I ordered the gearshift bushings kit from SLS on Monday morning. I have decided that if it keeps the forward gears long enough to get me home on Friday afternoon then I won't sell it. But if not...
Andrew
1966 230SL 4sp(forward only)
Hello Andrew,
Yes could be shifter bushings, but is also likely to be the reverse band adjustment on the transmission. The lock nut comes loose and the reverse band adjustment works its way out and reverse goes away.
If you find that the adjustment is loose, turn the 10mm adjustment in until just snug, then back it off 1 3/4 turns. Don,'t forget to tighten down the 22mm lock nut.
Hello Andrew,
If yours is a standard transmission, as I suspect now. Dis-reguard the previous post! It is the shifter bushings.
Joe
Yes, it is a manual/stick shift.
I had just about worked out that you were referring to an auto 'box and almost had the confidence to ask.
I am trying to build up my mechanical knowledge from a base of zero. So far I am practising on my Citroen 2CV which only has 500 or so very slow moving parts. The pagoda is another world.
In two minds whether to try to do the shifter bushings myself or not. It is a balance between the satisfaction of fixing it yourself and the horror of having to get it taken away on the tow truck.
Andrew
Joe
Andrew
You can imagine how it must feel when you have no one to ask and no place you can take it to get it fixed. Been there a few times - not fun........
Dr Benz
I could not agree more.
Although I have found a good local M-B specialist (on GGR's recommendation), the technical resources and help on this site are iinvaluable to prepare for very challenging discussions in French. French car parts and car repair vocabulary are much harder than "restaurant French" and I certainly find it useful to do some homework on what might be wrong with the car and then research the vocabulary in advance.
The first time I got my 2cv serviced the garagiste offered to change the "bougies". I knew that bougie meant candle; I did not know that it also means spark plug. I was standing there looking at my 2cv in disbelief thinking I know this is a heap of automotive junk from the middle of the last century but what do the candles do and why does it need new ones!
Andrew
No reverse is quite obvious to explain. But for other stuff you can send me what you want to say to your mechanic via PM and I will translate it for you.
Andrew,
you mentioned that your 2CV had only about 500 moving parts. While this seems true, you forgot to mention that this make about 100% of all 2CV's parts ;D
Andrew,
Indeed, when you slam a door, the three other open!
GGR
Thank you. Much appreciated.
No problems with the forward gears and I have taken the car into Garage Simondi this morning.
Now reduced to driving the 2CV for a couple of days. Life at a different pace.
Andrew
