W113 Pagoda SL Group => Electrical and Instruments => Topic started by: 250SLFranco on June 05, 2013, 22:42:58
Title: Brightest Headlight Lamps Available?
Post by: 250SLFranco on June 05, 2013, 22:42:58
I am considering replacing my old headlight lamps.  Has anyone done the research to find out what the brightest lights available for the U.S. might be?
250SLFranco
Title: Re: Brightest Headlight Lamps Available?
Post by: awolff280sl on June 05, 2013, 23:03:18
H4 55/100 halogens work, but the brights are not street legal in the US
Post by: Baybear on June 08, 2013, 17:09:41
If you want to keep sealed beams the Sylvania Silver Star would work. If you want something brighter the Cibies with an H4 bulb would be a good choice.
Baybear
Post by: Cees Klumper on June 08, 2013, 21:01:01
Does anyone know off-hand whether the power to the headlights is routed through the light switch in the dash, or whether the switch operates a relay that then channels power to the lights more directly?
Reason for the question is that on US cars of the era changing the wiring to be relay-based is a real upgrade to the intensity of the lights, because there is much less voltage drop.
Don't want to hijack this thread, but the question is related.
Post by: 71Beige280SL on June 10, 2013, 00:49:41
I just installed a set of the Sylvania Silver Star sealed beams. Huge improvement.
Post by: 114015 on June 11, 2013, 01:07:00
Dear Cees,
Quote
Yes, I do know off-hand. ;D
The power to the headlight is routed through the push light switch (foot dimmer switch) on the floor well/lower firewall and is left-foot-operated. :o
There is no difference between Euro and US regarding this (but only for the non-connected headlight flasher).
Pls. see the wiring diagramm which I sent you a couple of years back. ;)
Oh, it's in our Wiki :o 8) :D...; you can find it there as well. It's symbol no. 35.
Post by: Cees Klumper on June 11, 2013, 03:53:28
Thanks Achim - I knew this must have been detailed in the wiring diagram but I don't have mine handy. As the power goes through that switch as you say, that is probably ok then, the dashboard switch must then direct a relay. So long as the thickness of the wire to and from the foot switch is adequate, there should be no negative effect on the intensity of the lights.
