W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: magicman on June 29, 2013, 16:39:19
Title: 250SL 4 speed bushings for shift lever ball
Post by: magicman on June 29, 2013, 16:39:19
I'm replacing the shift lever ball bushings on my 250SL & I'm wondering if the wavy washer goes between the two nylon bushings or on top of both bushings with the snap ring on top?  Also all the diagrams only show one of this bushing part #82 (111 267 0086)? I thought you needed two?
Title: Re: 250SL 4 speed bushings for shift lever ball
Post by: magicman on June 29, 2013, 17:48:19
I figured it out. Both bushings then the washer & then the clip ring. Now I[m going to replace thr bushings on both ends of the shift rod.
