W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: jan lauwers on November 03, 2013, 10:47:26
Hello everybody,
I am struggling with something pretty basic: I can't find the MIN and Max readings on the cooling fluid expansion tank of my 280 SL (autom. 1969). I know that the fluid level is too low…. but how far should I top it up? Does anybody have a picture of such a tank showing the readings?
Many thanks… and have fun!
Jan
I just establish that 1) I can see fluid and then 2) inserting middle finger results in end third gets wet :-\
Larry is 100% correct, there is no reading level, just make sure that the tank has fluid to near the top.
I don't think near the top is correct ??? That the overflow tank has no level indicator is correct.
I make sure that the overflow tank is at 1/2 level it needs to be that way or you will have water overflow all over the engine and on the floor when the engine is hot.
Thanks a lot guys!!! :)
Jan
I will take a look tomorrow.
( Ik kijk er morgen eens naar en kom er op terug)
