W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Iconic on September 21, 2014, 15:59:52
Hi all,
Does this look like the correct Automatic Transmission filter for my 1970 280 SL?
My old filter does not have the rubber piece in the shape of a U as seen on the attached picture.
Thanks !
See attached image. There should indeed be a rubber lip on the screen filter, in U-shape.
Note the orientation of this however.
Note: Some filter brands have come delivered with the lip in the wrong orientation, or, there is no rubber lip present :o
Beware
/Hans in Sweden
Thanks Hans !
OK, but mine is exactly as you "wrong" picture is.
So, by re-orient the lip, do you mean I should pull it off and glue it down in the correct orientation?
I would not want to use any glue that might come loose with the fluid and heat.
Have you re-oriented the "U" before? How did you do it?
Does anyone know if I can re-use my brand new cork gasket. I've already torqued down the pan, but I have not put any fluid back in the trans.
Thanks !
.../... Have you re-oriented the "U" before? How did you do it?
No I haven't. I re-phrased my previous reply
As I understand it, there was a batch of filters delivered with wrong orientation...
Can you perhaps go back to the vendor and obtain a correct part?
I do not know if one can re-glue the "U" rubber lip oneself. I would suppose it is not trivial - this rubber would be attached with some industrial type fastener and attachment process, when manufactured
Re: your cork gasket, I guess you can try re-using it. If it later shows any leaking fluid, then replace.
Soak this item in ATF some hours, before mounting it.
/Hans in Sweden
Thanks again Hans.
I'm so glad you asked about the orientation.
I wasn't even looking at that and if you didn't mention it, I would have sealed it up and not known that it was wrong.
I have a good filter coming from the Classic Center.
So, I'll be all set.
Mark
