W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: gnj588d on October 28, 2015, 16:23:45
Title: Tie Rod
Post by: gnj588d on October 28, 2015, 16:23:45
Need to replace a ball joint on the offside front {UK car} tie rod would I be better buying the complete
tie rod and ball joints,thinking it might be pre set at the factory,any advice on fitting would be appreciated
        Cheers.Mike.
Title: Re: Tie Rod
Post by: Larry & Norma on October 28, 2015, 16:42:32
I think whichever way you do it you should have the steering alignment checked afterwards.
Title: Re: Tie Rod
Post by: stickandrudderman on October 28, 2015, 17:28:08
Personally I always recommend changing the whole track rod; they are quite often seized.
As Larry says, take the car for wheel alignment when you're finished.
Title: Re: Tie Rod
Post by: Benz Dr. on October 28, 2015, 20:46:32
107 tie rod assembly uses the same parts. Ask for that and you won't go wrong.
Title: Re: Tie Rod
Post by: gnj588d on October 31, 2015, 19:32:02
thanks for the info. sorted.Cheers >Mike
Title: Re: Tie Rod
Post by: alchemist on November 03, 2015, 03:20:35
Even VW tie rod works on Mercedes up to late 1970's.
