W113 Pagoda SL Group => Electrical and Instruments => Topic started by: catjim813 on February 01, 2016, 01:51:11
Title: Flashers/signal lights
Post by: catjim813 on February 01, 2016, 01:51:11
All, what would cause the flashers not to work when switch is activated?   signal lights work fine.  I replaced the flasher relay six prong switch but still the flashers will not work.  Is there a second flasher relay switch on a 69 280sl?
Title: Re: Flashers/signal lights
Post by: Kayvan on February 01, 2016, 03:58:29
Did U check the auxiliary fuse box; small square brown box with knurled screw.
It controls some lighting functions
Post by: Tyler S on February 01, 2016, 04:41:07
Catjim, Have a look at this thread. There are multiple ways the hazard and turn signals can be wired. All depends on year and if it was a US or Euro model. Lot of variables. Looking at the wiring diagram there is a seperate relay or flasher. It may or may not involve the hazards. No matter the hazards are fed from fuse #1. Always powered.
http://www.sl113.org/forums/index.php?topic=17648.0 (http://www.sl113.org/forums/index.php?topic=17648.0)
Post by: catjim813 on February 01, 2016, 16:48:45
Kayvan, and Tyler I will look at both once I get home from work.  The bracket is already down from putting in the capillary tube so I should be able to see the wiring and see if there is a second relay switch.  Thanks for the follow-up
Post by: Kayvan on February 01, 2016, 17:42:42
FYI see Manual too...may help
Post by: Tyler S on February 01, 2016, 22:00:29
Kayvan, I think he is going after the hazard-flashers. He mentioned the signals and the 6 prong switch (hazard switch)
