W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Kayvan on February 01, 2016, 22:52:37
Title: Red Rear Fog Light
Post by: Kayvan on February 01, 2016, 22:52:37
Going whole hog on Fog lights; may have to move to London to make use of all this Fog equipment  ;D
MB Part #: A 000 820 7256
Hella Part # 2NE 003 030-151
http://cat.hella.com/web/public/hasa/en_SA/700000/700232/Rear%2BFog%2BLight/$catalogue/2/$product/2NE%2B003%2B030-151_2488/index.xhtml
Title: Re: Red Rear Fog Light
Post by: Tyler S on February 02, 2016, 00:41:01
Are you going to run it with an extra switch or tie it into the front fog circuit?
Post by: Kayvan on February 02, 2016, 01:46:27
Probably run it to front fogs; finding the Green-lit pull-plug for console box may be impossible...
Post by: hauser on February 02, 2016, 03:30:55
I was thinking about doing this while my car is apart.  I found a light that I like although it's not period correct.  It may do a better job while keeping a low profile.
http://piaa.factoryoutletstore.com/details/0-72345/piaa-19155.html
Post by: Kayvan on February 02, 2016, 04:46:41
Looks cool!
I'm becoming a fan of <$100 mods for the SL, from lights to leather conditioner to tools.
Smiles per Dollars.
Saving my $$$ for an SLS!
Post by: Hans2012 on February 02, 2016, 05:19:30
If you are looking for one - the Classic Center sells the green-lit pull switch for the fog light.
Post by: dpreston Virginia on February 02, 2016, 15:46:18
Here is what an original one looks like on my 280SE
Post by: mnahon on February 04, 2016, 05:03:30
Is this the switch you're looking for?
http://www.ebay.com/itm/Mercedes-W108-W109-W112-W111-Single-Pull-Lighted-Switch-Green-31263001-108-109-/401052954108?hash=item5d609e6dfc:g:algAAOSw5VFWFrM4&vxp=mtr
Post by: Kayvan on February 04, 2016, 06:33:51
Yes, thanks
Noticed Hella makes this light as white reverse light too; as well as different red versions ...
Post by: Tyler S on February 04, 2016, 19:03:50
Kayvan, The small accy fuse box next to the washer pump on the booster bracket is what feeds your front fog lamps. You could tie the rear in there very easily to run with the fronts. Cant get much simpler.
