W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Charles 230SL on November 06, 2016, 22:55:56
My number 6 injector fuel line is leaking and I'm about to order a new line. I'm fairly sure that the fuel line part numbers are numbered consecutively, beginning with number 1 (127-070-12-33), and ending with number 6 (127-070-17-33).
Before I order a new injector line I'd like to confirm one more time that 127-070-17-33 is the correct MB part number for injector line #6 (injector 6 is closest to the firewall). Can anyone confirm? thanks,,,charles
Just checked the big parts book
127 070 17 33 listed as:
Delivery line (for 6th cylinder)
outstanding,,,thank you Jonny
Is it leaking at the fitting or is it leaking at the gland nut?
It's leaking at the 17mm fitting. I could probably tighten it a bit more to stop the leak,, I'm just not comfortable tightening it beyond specs. thanks,,charles
Has anyone ordered a new injector line from MB lately? I just hope it'll be yellow cad like my other ones....
It will arrive stock stainless finish no coating did mine a few months ago stock from MB
Try using some grease on the fitting compression surfaces before tightening. It helps things slide together smoothly and tightly, without binding or gaulding.
