W113 Pagoda SL Group => W11x chassis cars => Topic started by: dpreston Virginia on November 14, 2016, 14:52:39
Title: Shifter knob 4 speed 280se
Post by: dpreston Virginia on November 14, 2016, 14:52:39
I have a 69 280SE 111 4 speed. The shifter knob is loose. At one time you could tap on the top and it would stay snug for a while.
Can I glue it on or do I need a new knob? It is the original knob.There are no threads on the shifter shaft. It is a tapered shaft that the ball goes on.
Title: Re: A111 268 0942 - black 4-speed shifter knob
Post by: 114015 on November 17, 2016, 00:36:50
Hello David,
At a certain time point during the car's life a particular part wears out. Sooner or later.
That's the case with your shifter knob here. These parts are just not designed to to fine for  50++ years or so. They often do - for sure. But sometimes they don't.
If you had removed the know numerous times throughout any restoration tasks, the ball just wears out on the top of the shift stick.
Yes, your are right, there is no thread, it is just pressed on.
You have got 2 choices:
1st) (and best as to my guess) is get a new one:  ;) :D
A111 268 0942. €€ 56.00 in Europe; perhaps you can get a bit better quote from Tom.
Maybe Authentics etc. are even cheaper with repro shifter knobs, which are available as well.
With a car like yours (280 SE Convertible) I would always go with the original. 8)
2nd) Tape the tip of your shifter with some tape to get a tighter fix of the old knob on the shifter.
Or glue it.  ??? ::)
Both are temporary fixes - not suitable for a long future.
My 2 cents,
go with the 1st choice. Get a new one as long as those are available. 8)
The old one will make a fabulous paper weight on your desktop. :) ;)  :D
Title: Re: Shifter knob 4 speed 280se
Post by: Tyler S on November 19, 2016, 16:47:40
The tip of a black zip tie works great for a compression shim between the splines and the knob.
Post by: dpreston Virginia on December 03, 2016, 03:14:44
Ordered a new knob from Tom at the Mercedes classic center and hammered it on.
works great!!
