W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: WRe on June 14, 2017, 06:02:21
Title: Loud clatter when starting hot engine
Post by: WRe on June 14, 2017, 06:02:21
everything works fine with my late 280SL with automatic transmission, except when I start it hot.
When the motor is hot and it stands for half an hour there is a loud clatter from underneath for a few seconds (transmission in P). It disappears immediately when increasing the revs.
I checked all possible loose things but couldn't find anything. It seems to come from the driveshaft tunnel.
Any ideas?
...WRe
Title: Re: Loud clatter when starting hot engine
Post by: Rick on June 15, 2017, 14:43:10
This is an issue that could be anything.   A loose alternator bracket or muffler to a bad torque converter or loose rods, etc.   We would only be guessing.  I suggest that this be looked at on a stand with a person who can identify the source.
Post by: WRe on July 20, 2017, 17:40:56
I checked the flex plate and bolts of the torque converter, everything ok.
Then I replaced the transmission mount (rear engine mount; part no. MB A1202230412 or Meyle  0140220010) and it's gone but I coudn't see any damage of the old one.
We will see what will happen next.
...WRe
Post by: ejboyd5 on July 21, 2017, 11:09:34
Timing chain.
