W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Allforjags on September 13, 2017, 12:54:44
Does anyone knows why 280 sl has hose under the radiator with gearbox fluid. Is this for pre heating.
Thanks for answer
No, for cooling.
But water from radiator doesn't go throw this hose
Correct. In your radiator there is another small "radiator" only for the transmission fluid. The hydraulic fluid is separate from the coolant. Instead of having a separate radiator for cooling the hydraulic fluid they incorporated it in the coolant radiator. It is a method for cooling both system used to this day.
