W113 Pagoda SL Group => General Discussion => Topic started by: ricpang on May 20, 2018, 16:54:38
Title: very strange chassis number on a 230SL 1965
Post by: ricpang on May 20, 2018, 16:54:38
I am a new member, I live in Italy, Florence.  Just three days ago I have bought a 230 SL 1965 year. I bought it in Holland , I like it very much, it is a very good car, I have driven it from Holland to Italy (1400km) , no problems at all.  Well , now I have a terrible doubt. The chassis number appears not so clear, as if it had been reissued, and, what is worse, the first six digits  are 143 049, instead of the usual 113 042. On the documents the chassis  number is the same that is stamped on the chassis (143049 and the other eight digits.) I bought the car from a wealthy people that kept it since 1996 and mainteined it very well. It is not the kind of person that steal a car and change the chassis number. On your opinion what is happened?  Maybe the car had an accident and a piece of chassis has been changed and the number has been reissued? (stamped again) . Could you please help me to understand? Thanks in advance
Riccardo
PS: I apologize if I have mistaked the section in the forum, I am learning now.
Title: Re: very strange chassis number on a 230SL 1965
Post by: DaveB on May 20, 2018, 21:42:09
Hello ricpang,
Are you talking about the number stamped on the firewall plate or on the front RH frame rail? They should match. Ex-factory, the frame rail chassis number is unpainted as shown in the links below. Is yours painted or not? Are there any signs of repair/replacement? And are you absolutely sure the number is 143049??
In any case, I don't think you should be too concerned about fraud, because a fraudster would probably make a more believable number.
https://www.sl113.org/wiki/DataCard/VIN
http://www.silverstarrestorations.com/113SL.htm
Post by: ricpang on May 21, 2018, 06:17:44
Hello DaveB,
thank you for your answer. I was talking about the number on the front RH frame rail but also about the number stamped on the firewall plate. They match. The frame rail chassis number is unpainted and there are signs of replacement. Yes I am sure that the number is 143 049.  I think you are right , I have thought the same thing about fraudster. But I am asking myself the reason why.
Accident? or what else? And which number I should say when I will look for spares? Thanks DaveB.
Riccardo
Post by: Pawel66 on May 21, 2018, 06:26:45
Riccardo,
I think Dave's argument on that kind of fraud would be rather silly - there is no (to the best of my knowledge) 143 Mercedes car designation. Did you ask the previous owners about it? Do you have original car documents such as datacard or other document related to car delivery?
To me it looks like a mistake when the car was worked on. This mistake has then been legalized. I would check if the number 113 042 xxxxx can be used for parts. It would be great if you had a datacard for your car to chekc if the colours and options match.
What numbers do you have on the colour plate? Maybe send a pic.
Post by: Tyler S on May 21, 2018, 13:49:42
A mercedes "143" chassis was produced in the 1930's. Interestingly enough it was called a 230.
You may want to start looking for body numbers in the hood, trans plate, soft top compartment lid. Compare those to the body plate (not the vin plate) on the left side inner fender well and see if the Classic Center has a way of looking up a vin by cross referencing a body number on a 230sl
Post by: cabrioletturbo on May 21, 2018, 14:43:21
I tried cross-referencing build number to chassis number with the Irvine classic centre on a W111 and learned it was not possible. That said, I seriously doubt that any number punched on the body - unless it was the original chassis number - would help resolve this. If this was my car, I would go back to the previous owners to find out if there was any documents available when this change took place.
In North America there is a common practice where VIN gets 'assigned' by the state/province in lieu of the original, so that may be the case here. It would really be important to trace back this car as far as possible, to be able to get some sort of closure. I have seen several pagodas on eBay selling with VINs not corresponding to their actual chassis - being 110, 109, 108 or others.
As you described, you got a wonderful car to drive. That is important.
The correct numbers (chassis) are equally important. The issue you have with the numbers may impact resale value of your car once you decide to pass it along.
Post by: stickandrudderman on May 21, 2018, 15:24:59
In South Africa a stolen recovered car will have a new and completely different format VIN assigned and stamped into it.
Post by: cfm65@me.com on May 21, 2018, 15:51:37
Stick is correct. I once bought a ‘stolen recovery’ Golf from an insurance company and the cops stamped a new number on the drivers side( RH in SA) door sill.
The Model A Ford did not have a chassis nr and only the engine nr was used way back when, so when I registered my 1928 Pickup, a new number was punched in the RHD door sill by the cops.
Chris
Post by: 450sl on May 21, 2018, 17:39:37
When this car was registered in the netherlands since 1996 then there should have been a registrationpaper that stated a chassisnumber.
If as stick mentioned the chassisnumber was officially altered then this would clarify.
As long as both numbers match you should be ok.
Post by: ricpang on May 23, 2018, 17:38:48
Hello, thanks to everybody and excuse me for my delay. I have been very busy just for this matter of the chassis number. I wrote to Mercedes-Benz, I wrote to RDW,(it is a public car register in Holland, where I have bought the 230SL) , running here and there to try to resolve the problem and now I'm anxiously waiting their answer.   I already asked  the old owner but he said that when he bought the car was like it is now, he does'nt change the chassis number and he does'nt know anything about it. He says , and in some way he is right, that the documents are OK . The problem is up to me, because, to register the car in Italy, I need a technical data paper from the Mercedes and I don't know what they will do with that chassis number. Yes, Cabrioletturbo, it is a great driving indeed .  And thanks Tyler S. , I surely will look for any number everywhere and it is a good suggestion, Pawel 66, to have a look also at the number of the colour plate. Surely I'll do all these things. Thanks to everybody , I'll let you know how the thing proceeds.
Post by: ejboyd5 on May 23, 2018, 22:14:18
Several pictures of the various stamped numbers would be of assistance to those who wish to help.
Post by: TheEngineer on May 24, 2018, 02:32:21
If you write down your engine number and your transmission number and send them to MB Classic they can tell you which car they came from.
Post by: ricpang on May 24, 2018, 07:14:56
Oh , this is really good! thank you so much, TheEngineer!
Post by: TheEngineer on May 24, 2018, 14:48:35
Far niente
Post by: George Des on May 24, 2018, 14:59:01
I tried this to find out the orgins of a 5 Speed ZF that was installed in my 67 230Sl sometime between 1967 and 1976. The Classic Center said they did not have that kind of info. It apparently came from another SL of that period since this configuration of the S5-20 was only installed in 230SLs at that time. You think this would be a simple matter to figure out but apparently not. The bottom support plate for my ZF on mine is stamped with -043 which may be a partial of the original VIN this was installed in since it is not the same as the remaining body stamps on my car.
Post by: ricpang on May 24, 2018, 16:28:35
Hello to everybody,
today I checked numbers. First the colour plate. I don't post a picture because it is impossible to read the number on the picture. Only with a certain inclination and with very small distance between eyes and plate it is possible to read:
180 G  (the car is grey)
and this, that is very important to me: 113 042 10 plus a group of six digits and another group of five digits.
My question is: would this number on the colour plate be the same of the original chassis number (excluding the last five digits) ?
I didn't find any number on the hardtop neither on the softop frame nor in the compartment where the softop folds down. Do you know  special points in which look for? I have been looking for very carefully for a long time.
The engine seems to be from a 230SL  as the number says 127981 but follows 12 that, if I don't mistake, means  from an automatic car. Isn't it?(my 230SL is manual)   And the transmission number I found on the bell is :005104.  I say it for  TheEngineer and I ask him: if the engine is not original  can be useful to give to Classic Center engine and transmission numbers to obtain chassis number? Anyway could you please give me the address of Classic Center? The one I found seems not to deal with classic cars. Is it the one in Irvine? Thanks to everybody.
Post by: Pawel66 on May 24, 2018, 17:17:56
You have the explanation of the numbers from colour plate in the Technical Manual under Data Cards and codes section.
If the colour plate is from your car, your car had a regular 113042 10 VIN number - these digits are the same. The other digits beneath on the plate are productioin number and body number, different from vin. The colour of the car, 180G was silver grey metallic. The last three digits in the bottom line should be stamped on hood, etc.
The top line of digits (coming in 3 digits pieces) are the options for the car when it was order - you may try to see if this colour plate corresponds to what you have in the car.
Indeed the engine number indicates automatic (1 - LHD, 2-automatic). A lot of cars have engines that are type-correct, but are replaced.
Post by: ricpang on May 24, 2018, 17:59:24
Thanks Pawel66.
Post by: TheEngineer on May 24, 2018, 18:03:29
Tom Hanson
Supervisor, Parts Sales
Mercedes-Benz Classic Center
Mercedes-Benz USA
9 Whatney, Irvine, CA 92618
Email:     thomas.hanson@mbusa.com
Phone:   949-598-4842
Fax:         949-598-4860
Post by: Iconic on May 24, 2018, 18:11:55
ricpang,
Have you read through this? https://www.sl113.org/wiki/DataCard/BodyandPaintNumberPlate
Additionally, other parts of the manual will help you out too.
Good luck,
Mark
Post by: mbzse on May 24, 2018, 19:30:47
Quote from: TheEngineer
..../...Mercedes-Benz USA, Irvine, CA
Well but - the M-B Classic Center and Archive is in Stuttgart, Germany.  Lot closer (to Firenze)...  :o
Post by: TheEngineer on May 24, 2018, 20:43:32
Tom Hanson will talk to me and gives me excellent prices. I'm not so sure about Stuttgart. I'm a very old guy and remember "sal boche"
h
Post by: ricpang on May 25, 2018, 13:07:08
Thanks TheEngineer and also to you, Iconic. Sorry if I insist with the same questions, maybe I've made too many, and I have not yet been answered on where could be the number on the hardtop and  on the frame of the softop and, if it would be the same as the chassis number. For my case it is essential to find the original chassis number to be able to register the SL in Italy. Otherwise I will never be able to use it. (really terrible perspective!) I have looked for in any place, also inside the hub covers. Nothing. But if you are gonna tell me that the number I could find on the hardtop or in the softop frame or I don't know wherelse, it is different from the original chassis number , then I can stop to look for it. Thanks to everybody. Without you I would be very desperate.
Post by: Jonny B on May 25, 2018, 13:38:21
Take a look at this site, Motoring Investments it shows the location of the various body numbers.
https://motoringinvestments.com/historic/MainPage.htm
I don't believe the body number is on the soft top, it is on the cover to the soft top compartment. and the transmission cover under the car.
Post by: ricpang on May 25, 2018, 16:58:54
Yes, thank you Jonny B, the site you suggested helped a lot.
Post by: DaveB on May 25, 2018, 19:48:40
The body plate doesn't have the full VIN unfortunately. And the hardtop is stamped with the body number not the chassis number. But it could still be useful, at least to check whether it matches the other body components. The hardtop number is under the horizontal member below the rear window. You'll need to remove the hardtop and set it upside down to see the number.
TheEngineer's suggestion of using the engine and transmission numbers to obtain the chassis number must be possible. Apparently, there are also unique numbers stamped into each rear axle, left front axle, and steering box. Of course, as you've noted, your engine and transmission are not matched, so at least one and possibly both are non-original. Some of the other stamped parts could have been replaced over the years (does the car have rear drums or discs?), but it's less likely that all would have been replaced. Cross-matching the numbers should be simple for Mercedes but, as Igor and George have said, perhaps not.
You haven't told us whether substituting 113042 into your current VIN (i.e 043049-xx-xxxxxx becomes 113042-xx-xxxxxx) gives a valid number. I'm sure you already explored this, didn't it help?
Post by: DaveB on May 25, 2018, 20:08:57
I would be optimistic that, even if you're unable to determine the original VIN, you'll be able to somehow register with the new one.
(Of course I know nothing about Italian regulations :) )
Post by: TheEngineer on May 26, 2018, 02:39:10
I looked at this page from Motoring Investment. All that he says is true, especially that it is most important to get a car with a straight body and no rust. It is nice if the numbers match but I found that on my car where the numbers should be 6854 the lid for the soft top is stamped 6834. This lid has never been painted, it is the original red color that measures 4 mil thick (0.1 mm) and has no clear coat; same as the hood for the fresh air intake in front of the windshield. Why anyone would re-paint the entire car very carefully, even with a clear coat, but not these two parts, I do not understand. I think many people with big plans buy a car like this, dream about restoring, anticipate big profit and give up half way. It reminds me of a card game called "Black Peter" where the cards are passed around and the person who gets stuck, at last, with the card showing the Black Peter, looses.
Post by: George Des on May 26, 2018, 13:23:27
The Germans and most European countries are very fastidious in keeping records, especially on motor vehicles. I have Italian documents on my 230SL that go into excruciating detail describing the original owner of to car to the point of identifying who his children are. I have got to believe that the Mercedes Classic Center in Fellsbach has the wherewithall to do a reverse search of an engine, tranmission or other stanped body part to determine where it was originally installed and when. As I said, I tried in my case to have them trace a ZF with serial number 1675. They said they could not do it. ZF was able to tell me when it was produced and based on the serial number and another stamped number that the transmission was definitely destined for installation in a 230Sl. Apparebtly the ones that were installed in the 250/280SL while still S5-20s had some slight differences that were called by assigning different version numbers. I my case I have an -057 stamped above the normal ZF serial number.
Post by: ricpang on May 26, 2018, 18:35:21
I answer to Dave B: No, I did'nt try to substitute 113 042 to the actual 143 049. Do you mean to go to Mercedes and ask for some spares giving this number that begins  with 113 042 10 and follows with the others eight digit that are in the actual chassis number?
Or maybe there is another way to verify ? Inserting  the number somewhere?
Yes, TheEngineer,  it is possible. Now I have taken the Black Peter but I really want to keep it
and don't want to give it to anybody. But it's also true that I have the car since ...ten days.
No answers yet from Mercedes neither from RDW (Dutch car register)
 but I trust they will arrive within the next week. Have a good w.e. and thanks for your support.
Post by: DaveB on May 26, 2018, 23:13:52
Yes that's basically what I meant about the number. But there's no online lookup, nor would it help to ask for spares using the number. I recommend contacting Tom Hanson as The Engineer suggested. Describe your situation (maybe send him a link to this discussion), and ask if he can look up the 113042-xx-xxxxxx VIN and email you the data card corresponding to that car.
Note, if the last six numbers of your current VIN are not in the range 000000-19832 they're not original and Tom probably won't be able to help. Hopefully your local Mercedes and RDW will provide some useful information but I wouldn't count on it.
1400 trouble-free kilometres would have been a good bonding experience!
Post by: ricpang on May 27, 2018, 08:36:26
It is what I'm gonna do right now.  Thanks a lot DaveB! Fortunately the last six numbers are in that range. I begin to see the light at the end od the tunnel. I'll let you know any news  but it will take time. Bye.
Post by: ricpang on May 27, 2018, 22:42:12
DaveB, I have written to Tom Hanson. Now I need only to wait for his answer. I don't believe that linking the first digits to the last part of the chassis number could give some results as I have seen that a progressive number that is under 400 (like mine is) is referable to a 1963 car and my car,  being 1965 year,  should have a number  around 14000/15000. But let's see...
Post by: DaveB on May 27, 2018, 23:25:36
Good luck! Tom is a good guy and I think he'll help if he can.
If the car was made in 1965 the last six numbers should be in the range 009025-014779 (see www.sl113.org/wiki/DataCard/USModelYear)
As discussed by others, it seems the car's been assigned a new VIN after theft or an extensive professional rebuild early in its life. A new VIN might be assigned if, for example, front and rear clips from two written-off cars are assembled into a new car. I guess 043049 must have some meaning but perhaps only to the workshop that applied the new number or the jurisdiction where it was reregistered.
Post by: neelyrc on July 16, 2018, 06:48:02
Hello Riccardo, it has been about two months since you drove your car from Holland to Florence.  At the end of May you were still wrestling with the VIN issue in order to complete registration here in Italy. Have you been able to resolve this issue yet?
I hope you have been able to find a solution so that you can get on with the enjoyment of driving it.
Post by: TheEngineer on July 22, 2018, 19:54:07
It has finally come to pass: there is a highly portable lie detector you can take with you when buying a car. I can see only one problem: it may always show that
that sellers are lying and your only remedy may be to pay with fake currency
Post by: ricpang on August 19, 2018, 17:11:58
Hello Neelyrc,
unfortunately I am still in the same situation. I can't drive the car because in Italy it's impossible to make an insurance for a car with a Dutch plate and I can't have an Italian plate for the reasons concerning the not original  chassis number. I have had  a tight exchange with Tom Hanson MB Classic Center , a people of rare kindness and patience. It has been impossible to find the original chassis number. Now I don't know what to do. Yes, The Engineer, I should have bought  that lie detector but it is dangerous as it can backfire on me and detect my lies too. Goodbye to everybody.
Post by: ricpang on August 20, 2018, 14:52:03
Hello to everybody, I 'm going to ask you again your help. Someone of you could tell me where I can find the axles numbers? The points on which the numbers are stamped? I have been looking for carefully but the only number I found (only on the left front  axle) is 31 but it looks a too short number. Isn't it? On the right front axle nothing at all. And on the rear axle neither. Only on the differential a strange number:
14. (point)81    A picture would help so much .
And one more question: the numbers that I see on the glasses of the windows and of the windshield can they contribute to the identification of the chassis number? uhm...it would be a too fine thing!
Thank you in advance.
Post by: 66andBlue on August 20, 2018, 18:03:55
....Only on the differential a strange number:
14. (point)81    A picture would help so much . ...
Here is a photo of stamp on a 1964 230SL (3/75) and in this thread you'll find more photos of the stamp on different rear axles:
https://www.sl113.org/forums/index.php?topic=10523
Note that the ratio is sometimes shown as X/XX or as X,XX
Can you post a photo of stamp on your differential? Could it be 4.08?
Post by: Tyler S on August 20, 2018, 19:54:23
The rear axle serial number is on the drivers side housing top. Have a look at the 5th page of this link for location schmatic.
https://www.kkmfg.com/113%20Catalog.pdf
Post by: ricpang on August 21, 2018, 14:17:57
Thank you 66andBlue , the picture has clarified. Tomorrow I'll check on my differential. The link is useful but unfortunately they don't talk about front axles serial numbers, but only about rear axle numbers and gear ratio. Anyway it' s more than something! I am already halfway there!
And thank you Tyler S. for this good catalog. I didn't know it but now I understand that is a "must'. I downloaded it . I did'nt find, at page 5th, nothing about axle serial numbers and in all catalog neither. Anyway thank you , I liked the catalog, it can be precious. I am still looking for the location of the front axles serial numbers. Hope to succeed.
Post by: Pawel66 on August 21, 2018, 17:26:30
Well, you have locations of the serial numbers on particular car components on page 5 there. It is easier to look for them if you know where to look - sometimes you need a solid piece of cloth with some cleaner or a wire brush to find them - but you need to know where to look for them.
Post by: 66andBlue on August 21, 2018, 18:52:13
.... I have been looking for carefully but the only number I found (only on the left front  axle) is 31 but it looks a too short number. Isn't it? On the right front axle nothing at all. ...
You are correct, "31" is NOT the axle number. Look around the steering knuckles (or in German "Achschenkelbolzen") / kingpins for the number.
Post by: ricpang on August 22, 2018, 06:43:22
Yes, I will do it, 66andBlue. Do you think I need to take off the wheel to look for front axle serial number?
Post by: Cees Klumper on August 22, 2018, 11:13:10
Ricpang - are you sure about needing a certificate from MB for the Italian registration? I ask because NL and Italy are both EU which should be fairly easy to convert if you have proper Dutch paperwork, which you do. You could try with the changed chassis number and approach Mercedes for the certificate, who knows maybe they will give it.
When I imported my 280 SL from Switzerland (non-EU) into France in 2016, the French authorities also would accept a declaration from the French classic car club on the car, instead of the manufacturer's certificate. I requested that and recrived it, all I had to do (as I recall) was send a copy of the title and photos of the car and 50 euros, and they sent me the certificate. Maybe there is a similar alternative in Italy as well. Good luck. Your not so great alternative would be to sell the car in Holland again, and find another one. You might even make a profit...
Post by: ricpang on August 22, 2018, 11:30:00
@ Cees Klumper: I have already tried with Mercedes. Nothing to do. It was Mercedes-Italy that asked to Mercedes-Stuttgart. I waited for two months only to know that it is impossible to have the document. But now I'm trying with a historical cars club. I will have to wait for "only" three months and after another month to make registration and revision of the car and finally  I will have the italian plate. Much simple! If you think that the car has everything Ok (also Dutch APK valid till 2020) But I can wait for. I have no alternative. Thank you for your message. I'll let you know how the thing has gone. Bye.
Post by: ricpang on August 22, 2018, 12:02:29
Thank you to everybody: I found the rear axle serial number! Many difficulties to find the front axles numbers. Someone of you could tell me where they have stamped ? I looked for them in this site but
I diid'nt find anything that could help.
Post by: ricpang on August 29, 2018, 16:56:05
I re-read my last post and I think the last sentence was bad. Please don't get me wrong. I love this site.It's really exhaustive like no other.
Post by: Tyler S on August 30, 2018, 13:44:45
Location of front axle (kingpin) serial number.
Remove the wheel for a better view
Post by: 114015 on August 30, 2018, 16:40:55
Strange ... :o
Here is where you can find the kingpin assembly numbers.
Those numbers should be indicated on your datacard as well.
Post by: ricpang on September 11, 2018, 17:00:41
Thanks a lot 114015 and TylerS.  :) :) :)
