Off Topic => Way Off Topic => Topic started by: mdsalemi on September 02, 2018, 12:35:50
Title: Any TV or electronics gurus out there??
Post by: mdsalemi on September 02, 2018, 12:35:50
Yeah, this is way off topic but knowing we have a diverse group here I'd thought I'd post the question.
I just bought a bunch of cheap little "boxes" on Amazon for my 96 year old father who just bought a brand new TV when his died. The TV he bought did not have enough HDMI ports, and no analog audio out, and no analog in. So he couldn't connect everything the way it was on the old TV. So, little converter boxes were the answer.
So, this is what I bought for him. First, an HDMI switch, which takes four HDMI inputs and sends them to one output. Now, he has everything connected.  Second, a digital to analog audio converter, which takes the TOSLINK fiber optic digital audio out from the TV and converts to analog audio, for his headphones. Lastly, a composite analog to digital HDMI converter which connects his old VHS recorder to an HDMI input so he can still watch his old tapes. It all works perfectly! These little converter boxes cost between $10 and $20 each. Perfect, cheap solutions.
So what's MY question and problem?  My largest TV at home had the HDMI inputs blow out during an electrical storm. The TV display is fine, and I actually moved it to a room in my home with an old fashioned antenna; reception is perfect. The antenna is connected with a coax connector. But, I'd like to be able to use this with an HDMI input--but as noted they are all dead. So, what I'm looking for is something that would convert an HDMI (output) to a coaxial antenna input. It can't be expensive of course, else I'd just buy a new television.
Years ago, before manufacturers started putting inputs of any kind on a TV, when you had a VCR they plugged into the antenna and you had to tune your TV to "channel 3" or some other unused channel. So, these kinds of things are possible. Just don't know if they exist, and if they are in that same cheap price point as all the other converter boxes I just bought!
The problem is I don't know what I'm looking for--I don't know if it has a name, and thus my searching has been fruitless.
Title: Re: Any TV or electronics gurus out there??
Post by: mrfatboy on September 02, 2018, 15:34:10
This should help 😜😜😜
http://bfy.tw/Jh97
Monoprice.com might have them.
Post by: Pawel66 on September 02, 2018, 16:12:16
 :D :D
Jokes aside...
Michael, you have probably been too busy with badges, pins, etc....
You need someting like this, I think:
https://www.ebay.com/itm/1080P-HDMI-To-SDI-Converter-Adapter-Coaxial-Cables-Video-Audio-HDMI-Extender/112633829458?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D20150817211709%26meid%3D08e6bf1a18c64b90a830e18fee6de37a%26pid%3D100506%26rk%3D1%26rkt%3D1%26%26itm%3D112633829458&_trksid=p2045573.c100506.m3226
Post by: specracer on September 03, 2018, 11:54:05
Your looking for HDMI to a QAM  modulator. Many available, but most cost more than a new TV. One also might wonder if cheap options will be HDCP complaint, meaning it might not work with an HDCP device like a cable box or DVD player etc.
https://www.ebay.com/bhp/hd-modulator
https://www.amazon.com/ZeeVee-ZvPro810-Video-Distribution-Modulator/dp/B00IMN1VCI
Post by: Peter van Es on September 03, 2018, 12:54:06
http://bfy.tw/Jh97
Ha ha  :) :)
Post by: Tyler S on September 03, 2018, 15:10:22
This will do exactly what you want for ~$40. No more, no less.
Just keep in mind that any type of cheap converter that uses an off air coax output will degrade the quality to SD (standard definition). There is no way around this as the TV tuner only pulls uhf/vhf. Cheap Converter boxes with DTV (high def) output on coax simply do not exist as there would be no reason to do so with a functioning HDMI port on the TV (hence your issue) What other inputs besides HDMI (if any) do you have on the TV. S-Video, Component?
https://www.radioshack.com/products/radioshack-hdmi-to-coax-adapter?variant=26394140752&gclid=CjwKCAjwt7PcBRBbEiwAfwfVGPbwikexxmfvosGEBeP2BngiYLDJRemSeFzw0RGzTVcAK2vrHJwWMBoCJ4QQAvD_BwE
Post by: specracer on September 03, 2018, 23:32:54
The modulators I suggested are HD (hence the expense). I would have to assume if trying to connect HDMI, the desire is to have HD, vs SD.
I do like the SVHS reference. And the days when we debated which components comb filter was better, and if to use SVHS or composite.
Post by: specracer on September 03, 2018, 23:41:35
Not exactly. VHF has been reclaimed by the FCC, UHF now carries digital terrestrial digital HD signals. In fact these are BY FAR the best picture you can get, hands down, as it's uncompressed 1080i or 720p (all cable and satellite companies compress their signals to some degree). Terrestrial HD is breathtaking quality. If a TV has an HDMI input, it for sure has a QAM tuner (digital HD RF input), as QAM distribution started before HDMI (component days).
Just keep in mind that any type of converter that uses an off air coax output will degrade the quality to SD (standard definition). There is no way around this as the TV tuner only pulls uhf/vhf.
Post by: Tyler S on September 04, 2018, 14:07:45
Ok will insert “cheap” into said context
Post by: mdsalemi on September 04, 2018, 14:56:42
I'm narrowing things down a bit but still don't know if what I want is made. But in some further searching I'm not the only one asking...
Tyler, yes speracer is correct. OTA, or terrestrial DTV HD signals are HD and astounding quality. Any SD or 480p solution isn't viable. Though it's an older TV, it is 1080p, 16:9 aspect ratio, and the picture is great. The only HD inputs are HDMI and the antenna. I don't believe the S-Video and the Composite inputs (RCA jack) support HD.
Pawel, SDI is serial digital interface, that's not the same signal that an antenna generates as input to a TV. So, those SDI converters won't work. (but the price is right and they are the right size!!)
Mr. Fat Boy, well that was funny just for the amusing animation. Didn't help me as I'd done that many time with slightly different search criteria already before coming here.
http://a.co/d/gNabTsi  Now I know that what I'm looking for is an "HDMI to RF Converter (or modulator)" That box will do the trick but not certain of how bad the picture will be...
Post by: specracer on September 04, 2018, 16:00:26
Nope, composite, and SVHS are not HD. The only analog HD, will be component (the red green blue RCAs) or RGB. your TV doesnt happen to have a DB-15 VGA " computer" connection?
HDMI to QAM (modulator) picture quality  should be acceptable. The most common application that comes to mind is a bar / restaurant where they can have just a few cable boxes, then easily distributed to many TV's. Much cheaper than a matrix switcher.
Post by: mdsalemi on September 04, 2018, 18:13:13
...your TV doesn't happen to have a DB-15 VGA " computer" connection?
Why yes it does. Have never used it, thus I don't know if it works.
During an electrical storm in May, all the HDMI ports blew out, as well as the HDMI switch I was using. I tested them all repeatedly, even left the television unplugged for a day, but still no HDMI. That means no cable box, no Roku, no Blu-Ray. So I moved the TV to a bedroom where we have a good old fashioned antenna. Since all the local stations broadcast HDTV OTA, it's fine but if I could move this back downstairs (where a Roku connection is a requirement) I'd be happier.
Post by: Tyler S on September 04, 2018, 20:04:13
Yes I know OTA digital is HD 1080. I am referring to an adaptors output. Because the original question stated was looking for a low cost. You wont find one that outputs digital UHF for a reasonable price. May as well replace the set. The talk of hooking up vcr’s etc led me to believe quality was not a concern.
Post by: mdsalemi on September 06, 2018, 13:15:31
I'm hoping this device will do the trick:
http://a.co/d/hWH2ozb
I'm hoping that the SVGA or VGA DB15 input to the television works. I have not had a device that uses that format since my last Windows laptop...about 10 years ago or more, so I have no way of testing it. But, the TV has this input, and the price is right so we'll give it a go.
Thanks for the insights Tyler and speracer.
Post by: specracer on September 06, 2018, 23:28:52
Happy to help, almost 30 years in the AV business.
I have my fingers crossed that this non rules following device with regard to HDCP (high-bandwidth digital copy protection).
Hope it works!!
Post by: mdsalemi on September 07, 2018, 12:46:01
In the Amazon review section, there were well over a hundred answered questions, and a number of them indicated first hand experience that it will work with a Roku (my one and only goal with this). So, my fingers are crossed, too. Some outlier said it didn't work with a Roku, and it burned out their Roku stick...but I think they were trying to connect to a PC or Laptop, not a Television. I suppose it depends on the television.
My older Sharp is a weird one--for example, the digital audio out (Toslink) only provides a signal for audio generated internally via the tuner. Thus, if you have any kind of modern soundbar connected via the fiber link, and your audio/video source is external (cable box, Roku, Apple TV, blu-ray, etc.) then no audio is passed. Brilliant engineering...NOT!
Post by: specracer on September 10, 2018, 23:07:33
Welcome to my world.
If you want to extract the audio out of the HDMI signal before getting to the TV, this will do it. It works, we have used it several times.
https://www.monoprice.com/product?p_id=10251
Post by: mdsalemi on September 11, 2018, 14:15:56
I did have my ideal setup for about a year or so, that ended in May with a typical midwest electrical storm. No real damage outside anywhere, just invisible power surge that fried my HDMI switch (that had a Toslink audio extractor built in), as well as fried all the HDMI ports in my television. I went to my other house at one point in the summer and all the HDMI ports appeared dead on my newish SmartTV there, but luckily, they did wake up after being unplugged for a while. Conclusion: HDMI is way too sensitive to external forces to earn the name "robust". Too many darn issues with it. An online forum search yields I'm not the only one with overly sensitive HDMI issues.
So, my soundbar sits unused and I wait until we update the TV before investing any more money into it. As with many folk, due to the sizing, updating a TV also requires updated furniture and that's the larger issue...
Post by: specracer on September 11, 2018, 14:34:10
HDMI is light years ahead from where it was.... We held on to component for a LONG time after HDMI came. It worked, you could distribute it, it was perfect. Time moves on, and so does content, and copy protection. HDMI is here to stay. The "analog sunset" has long since happened.
Post by: mdsalemi on September 11, 2018, 15:48:52
Yeah, that's all well and good. But when these inputs (HDMI) can't outlive the device they are attached to, usually significantly larger and more complex, than a lesson in robust electronic design is needed, instead of thrifting. I'm not criticizing anything but how robust the hardware is to external forces; how strong it is against these forces before a perfectly usable TV becomes landfill because the inputs don't work. Static happens. Power surges happen. Search the infinite audio, video, TV, HD, etc. forums and you'll see what I mean. If my TV were 5 years old instead of 10 it would be landfill because it is unlikely it would have many alternative inputs. Many today are simply 2 or 3 HDMI and that's it. Once they go, the TV is toast.
Post by: specracer on September 12, 2018, 21:54:47
PM or e-mail me if I can help in any way further
