W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Kevkeller on October 01, 2018, 16:04:31
Title: 2 Cylinders not Firing
Post by: Kevkeller on October 01, 2018, 16:04:31
I had to take my FIP out to unfreeze a few of the plungers. I put the pump back in according to directions (timing wise).  I’ve been able to run the engine but it seems like number 3 and 4 cylinders are not firing.
1. I pull the spark plug wires and don’t notice any drop.
2. I loosen the fuel injector lines and both have fuel coming out.
3. I replaced both injectors with brand new injectors.
4. I’ve checked compression, both 160#’s.
5. When I have removed the spark plugs they are wet.
6. The plugs have a strong spark.
7. I’ve used a glass spark plug to watch the actual combustion. I see the spark but not sure if it’s igniting the mixture. A good cylinder shows a lot more light from the combustion than #3 and 4.
I used an aluminum drift to loosen up the frozen plungers so I don’t think I damaged the plungers.  It didn’t take too much persuading to get them to move. I’m quite sure the plug wires are in the correct position.
Any ideas?
Title: Re: 2 Cylinders not Firing
Post by: Benz Dr. on October 01, 2018, 16:18:55
Go back and check plug wires to make sure they're timed right. Small possibility you have a vacuum leak.
Post by: A Dalton on October 01, 2018, 20:02:39
  1 5 3 6 2 4   CW
#1 is @ front of engine.
Post by: Shvegel on October 01, 2018, 21:10:19
Any dirt between the delivery valves and the top of the barrel (Cylinder) in the injection pump can cause an internal leak in the pump that will reduce the amount of fuel delivered to the cylinders. you might be getting fuel against no back pressure but with the line tight it has to make 200PSI to open the injector.
Post by: Kevkeller on October 02, 2018, 07:17:34
I’ll try to check those things in the morning. Thanks for the comments.
Post by: Kevkeller on October 02, 2018, 07:26:21
Pat,
Are you talking about the check valves on the discharge side of the FIP?
BTW I haven’t forgotten about the package I’m sending you.  I’ll hopefully get it out soon.
Thank you.
Kevin
Post by: ja17 on October 02, 2018, 21:44:50
Make sure the fittings on the IP are torqued to specs 18ft. lbs, or 21 ft lbs on a 280
Post by: Shvegel on October 02, 2018, 22:32:32
Yes. The discharge valves of the pump.  The nylon washer only keeps the fuel from leaking out of the pump above the delivery valve.
Post by: Kevkeller on October 03, 2018, 01:31:15
Joe,
I’m curious why you said that. Is it for leaks or would that effect the output of the pump itself?  I did torque the check valves  to 21 initially but they leaked so I upped it to about 25# and it stopped. Maybe my torque wrench isn’t that accurate.
Kevin
