W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: paults1 on February 15, 2019, 20:33:38
Title: Fuel injectors early type vs. late type
Post by: paults1 on February 15, 2019, 20:33:38
Will the late type Fuel injectors work ok in an early 230sl. Early type #A000 078 0723, #on the injector DC8C45R1. Later type #A000 078 1123,#on the injector DC8C45R2. Is there any consequences if I use the later type?
Regards, Paul '63 230sl
Title: Re: Fuel injectors early type vs. late type
Post by: mbzse on February 15, 2019, 20:49:02
Yes, you can install Bosch "R2" injectors in your Pagoda engine
As far as I know, the "R1" is no longer available.
Mercedes as a matter of fact do state that you should not mix R1 and R2 injectors in one engine
Post by: PeterPortugal on February 16, 2019, 11:04:59
Well Hans, you surprised me there.
Due to their very different size and shape I did not think it was an option.
I shall bear it in mind if I come across a set for sale.
Post by: WRe on February 16, 2019, 15:29:10
the R1 injectors have been replaced by R2 injectors, R1s are no longer available. They are more or less the same, afaik a slightly different spray angle.
As Hans mentioned only one type should be used, no mixing of both.
...WRe
Post by: mauro12 on September 24, 2020, 21:49:42
I have just bought a set of 6 brand new bosch injectors and the car run terribly. No idle , no acceleration and huge smoke.
I will put back the old one but honesty how is possible that a new injectors fail so badly? Maybe they are fake bosch?
