W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Rhinkel on August 11, 2019, 06:10:01
I am missing the fuel pump cover, long pump, and the 3 shouldered bolts that go through the trunk pan on my 69280 SL. I can find the cover easy enough but not the special bolts. Anyone have a source ? Thx
These are special bolts with a square clip built into the head of the bolt. They secure into a square hole in the trunk floor. Your local MB dealer can order them for you. Also I think I saw them on the Authentic Classics website.
Here you have the link to source for Europe and Mercedes PN is there as well:
https://www.niemoeller.de/en/w113/w113/B044/472/c47017a-screw-with-locking-plate
this bolt is also available at MB for 17,75€ each or here https://www.sls-hh-shop.de/main/de/mercedes-190sl-w121/61-chassis-rohbau-und-beplankung/64-heck/schraube-mit-sicherungsblech-p-2807. Should be the same to fix brake and fuel lines: https://www.sls-hh-shop.de/main/de/mercedes-230-280sl-w113/42-bremsen/42-c-bremsleitungen/satz-leitungshalter-113-euro-standard-p-5297.
...WRe
Wow. Thank you for the info.
Also.....
https://www.authenticclassics.com/Round-Head-Screw-with-Lock-Plate-for-Body-Panels-p/auth-008381.htm
I used regular bolts, about $4 for 10.
These are special bolts with a square clip built into the head of the bolt..../...
One important feature of these bolts and the mounting of the fuel pump housing/cover are the seals, otherwise water may enter the trunk at these three points
On top of the sealing feature, they also look "civilised" in the trunk and, as they click in place, one pair of hands is enough to install them.
I sealed the holes with a washer. They are covered by the rubber trunk floor mat so invisible.
Got them on order. Thx
