W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: mistertj on April 27, 2020, 22:56:15
Title: Wrong NGK BP5ES Spark Plugs Problem Solved
Post by: mistertj on April 27, 2020, 22:56:15
Got the NGK BP5ES plugs but there is a problem. I ended up with 2140 BP5ES plugs that have a non removable top. Does anyone know the number for the plugs that have a stud top? I looked at the 7832's and those have a screw top but the stud is short.
Title: Re: Wrong NGK BP5ES Spark Plugs
Post by: Vander on April 27, 2020, 22:59:34
I use 7832 all the time on many cars, never any issues.
Post by: WRe on April 28, 2020, 08:26:42
are you shure that your SAE-terminal is fix, non removable? Sometimes it's very tight.
If you look in NGK's spark plug notations you'll find a
- "B"= integral terminal/non removable terminal top instead of a
- "S"=standard/removable terminal top.
But there is no BP5EB but a BP5ES with order code "6511".
You can download complete NGK catalogues here: https://www.ngkntk.com/service/downloads/#Catalogs.
...WRe
Post by: mistertj on April 28, 2020, 14:11:22
Went to NGK catalog and they list NGK BP7ES / 2412 plugs. Could not find in the US so have purchased from the UK.
Post by: Pawel66 on April 28, 2020, 14:23:32
I found that sometimes it is easier to find those plugs in motorcycle sections of the stores.
Post by: mbzse on April 28, 2020, 14:46:46
Quote from: mistertj
.../...Could not find in the US so have purchased from the UK
I found a number of US vendors for these NGK plugs, on e-bay.com
Post by: Benz Dr. on April 28, 2020, 14:50:34
I get them at my local NAPA store.
Post by: Vander on April 28, 2020, 15:04:07
Advance Auto Parts has them in stock. Try the # 1034
Post by: wwheeler on April 28, 2020, 15:33:58
Yes, Napa for me as well. Always has them in stock.
Post by: FresnoBob on April 28, 2020, 16:15:23
I ran into the same problem.  The box and part number is identical, but there is a small box on the side that has a check mark for the removable type or non-removable type.  Really strange and must be a big headache for stores.  I bought the wrong ones and tried to remove the top.  Didn't end well...
Post by: mistertj on April 28, 2020, 19:40:09
Just got the right ones. The auto parts guy was also surprised.
Title: Re: Wrong NGK BP5ES Spark Plugs - Got the right ones now
Post by: mistertj on April 28, 2020, 19:41:06
Title: Re: Wrong NGK BP5ES Spark Plugs Problem Solved
Post by: mauro12 on October 26, 2020, 11:58:40
Which one is the correct serial number for removable cap? I just bought 6 Bp5es but I cannot remembar  the serial number and I’m away from home .
Post by: Mike Hughes on October 30, 2020, 14:02:46
7832
