W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Charles 230SL on January 31, 2022, 19:22:36
Title: Passenger Door Pull
Post by: Charles 230SL on January 31, 2022, 19:22:36
Hello all,
My passenger 'door pull' has been missing since I've owned the car and I'd like to try and install one without removing the door panel. Would anyone happen to know where I could find measurements for the red X's in my photo below? Installation of a passenger door pull has been discussed several times over the years but I can't find any measurements for the four screw holes. I want to make sure I get the holes marked correctly before I puncture the leather. thanks in advance for any info, Charles
Title: Re: Passenger Door Pull
Post by: dirkbalter on January 31, 2022, 19:39:56
Charles.
My panels are removed. Unless someone chimes in before, I can send some dimensions tonight.
Post by: Jordan on January 31, 2022, 20:47:00
Charles, have you tried feeling around the surface with your fingers?  If memory serves, the hardboard behind the vinyl/leather cover has holes in it where the door pull is screwed to the door.
Post by: MikeSimon on January 31, 2022, 20:56:59
Isn't there a metal piece behind the panel, where the pull mounts to? Seems strange that it would pull at the panel.
Post by: Charles 230SL on January 31, 2022, 21:21:59
..have you tried feeling around the surface with your fingers?  If memory serves, the hardboard behind the vinyl/leather cover has holes in it where the door pull is screwed to the door.
Yes, I've tried pushing in/around the area with my fingers but I can't detect any holes in the hardboard. I'll use a blow-dryer to heat the leather and see if I can feel the holes once the leather is more pliable.  Dirk, it would be great if you could post dimensions/measurements for the (4) holes. thanks in advance, Charles
Post by: mbpaul on January 31, 2022, 21:58:33
Although there are no dimensions, if you go to ebay and look for "Mercedes 113 door panel", there are some pictures of used door panels with the holes shown.  Not exact but you can get a better idea of where the holes should be.
Post by: BobH on January 31, 2022, 22:13:49
https://www.sl113.org/forums/index.php?topic=18284.msg155893#msg155893
Have a look here at post 1440. The door pull screws into these threaded holes in the frame, no dimensions, but the holes in the door lining need to line up with these threaded holes
Post by: Charles 230SL on January 31, 2022, 23:22:29
thanks Bob, great photo from Andy Burns - I would have never found it.
The more I study the photos the more I realize I'd best go ahead and remove the door panel - looks too risky (punching through the leather and 'fishing' for those screw holes).  thanks again,, Charles
Post by: BobH on January 31, 2022, 23:33:29
https://www.sl113.org/forums/index.php?topic=16914.msg119256
Hello Charles, if you're going to remove the panel, have a look at post 6 for a tip on how to mark the hole positions, probably the most fail safe method
Good luck!
Post by: dirkbalter on February 01, 2022, 01:33:08
May be that helps. As Mike already said, you should be able to feel the soft spot
Let me know if you need anything else?
Post by: dirkbalter on February 01, 2022, 01:39:24
Mounting in the door
Post by: dirkbalter on February 01, 2022, 01:47:41
And (new) panels.
Post by: Charles 230SL on February 01, 2022, 02:21:35
Outstanding! thanks Dirk!
Post by: Jonny B on February 01, 2022, 03:22:30
I would recommend you check the condition of the threads in the door. When Mrfatboy and I were doing some work on the windows last year, I discovered that the threads were in pretty sad shape. I ended up going one mm larger as the threads were stripped out (using a sheet metal screw no less!). It was so iffy, that it was a standard warning for any passenger to never use the door pull. Now corrected., albeit with one size larger machine screw thread.
Post by: Charles 230SL on February 01, 2022, 12:43:41
I would recommend you check the condition of the threads in the door..I discovered that the threads were in pretty sad shape.. I ended up going one mm larger as the threads were stripped out..Now corrected., albeit with one size larger machine screw thread.
thanks Jonny., yep, I thought about that (threads being stripped out). I'll be prepared to cut new threads in the door frame. The door frame appears to be aluminum in Dirk's photo - are the threads for the pull handle cut into aluminum or steel?
Post by: dirkbalter on February 01, 2022, 15:33:24
Yes, checking the threads and repair if necessary is good advise. They are tapped into the aluminum.
Post by: mdsalemi on February 01, 2022, 15:49:11
In my case on the door pull for the driver side which of course is also the armrest, I too had a situation where the threads were too weak and eventually stopped working. The whole thing just pulled out on one end.
The first repair done by my mechanic was with a steel rivnut. That worked briefly but eventually pulled out. For the second go around they brought out the big guns: using an aluminum welder they filled the hole completely and then re-tapped it.
The beauty of this repair was they were able to add more metal than was there originally thus giving more threaded area. So it’s a stronger fit now.
Post by: Charles 230SL on February 01, 2022, 16:21:43
Well, since the threads are tapped into aluminum, they're most likely stripped out - which may explain why Bud's didn't install the pull handle when they trimmed/upholstered my interior 8 years ago..
I've got access to a TIG welder but I'd rather not strip the door down and attempt filling in the holes. Is there enough room to epoxy nuts on the backside of the frame and use screws to secure the handle? (I've not removed the passenger door panel yet and that's the reason for all the questions).
Post by: dirkbalter on February 01, 2022, 16:58:41
The threads are M5 but I can check to be sure. If they are stripped I would just drill them out and tap M6 as suggested. It looks like there is enough room to clear the bigger bolt heads. There are other ways from rivet nut to threaded inserts…. Not sure I would start welding on a finished door.
Post by: wwheeler on February 01, 2022, 21:06:36
M5 helicoil will work just fine. I have used those in a few places in the cast door frame. Buy the set that comes with a drill, tap and inserts. One word of caution - use thread lube when tapping. The super soft door frame alloy will gum up the tap and wreck the threads when pulling the tap out. Ask me how I know.
Post by: Pawel66 on February 01, 2022, 21:10:52
I would have thought they are M4. M4 heli coil set will work just fine.
Post by: mdsalemi on February 01, 2022, 21:48:44
As I recall, the challenge with the rivnut on mine was that if you look at one, what holds it in place and prevents it from "spinning" is a very mild splining. Well, it really didn't take much torque (a/k/a shear  or twisting force) to rotate the rivnut in the now newer and larger hold drilled to accept it.  :(. Rivnut makes hex shaped rivnuts, but they require a hexagonal hole. I seem to have lost my hexagonal drill bit  :D; but their installation instructions say, "...laser a hex hole into your parent material..." Oh, yeah, I'll just go to the back and get the high powered laser to cut a hex hole...
Not certain why my shop didn't try a helicoil, I know that as a serious mechanic shop, body shop and restoration shop they surely had all of these "fixes" laying around.
The overriding issue here is the "parent material" that we're talking about--the door frame--is extremely soft material and doesn't put up with repeated installation and removal of screws. Otherwise we wouldn't be talking about this!
For many amateurs, the thought of bringing out a TIG welder on a finished door may be daunting. For professionals it was no big deal. Filled and re-drilled and re-tapped.
Post by: Pawel66 on February 01, 2022, 21:56:26
I used rivnuts in a lot of places requiring high torque fastening - never had any issues. The difference may be if they are aluminum or steel. But anyway it is not only the spline that holds them in place and prevents from spinning, it is more the crimping force applied during installation. You need to have proper riveting pliers (or what is the name of this device in English?).
I also do not think that the frame to which door handle attaches is a good place for rivnuts, particularly small diameter ones. They would be too short and the frame too thick to crimp them properly. These rivnuts work on metal sheet, not a bar type of frames.
I do not, however, recall seeing M4 rivnuts. I also think helicoil (or alike) is the best solution for the particular place in question. Or re-threading if possible.
Post by: dirkbalter on February 01, 2022, 22:27:12
As Paweł already said, you need proper pliers to “rivet” the nut in place. Just Pushing or pressing them in and rely on the splines for fastening is not going to cut it.
Post by: dirkbalter on February 02, 2022, 02:30:29
Just checked, Paweł was correct, the threads in question are M4.
Post by: Charles 230SL on February 02, 2022, 03:00:08
got it, thanks Dirk.  If the threads are stripped I'll go with a (M4) Helicoil and as Wallace recommended, I'll get a kit with a drill, tap, and inserts.
thanks all for your help. I'll let the group know how it goes. Charles
Post by: Pawel66 on February 02, 2022, 06:34:41
After some experience i now put some red Loctite on the helicoil "spring" when I screw it in.
Post by: MP on February 02, 2022, 08:37:07
My door pull has always been on the driver side and none on the passenger side. Was this an option or was it fitted by the first owner?
Post by: Pawel66 on February 02, 2022, 10:16:35
Very early 230SLs had it on both sides, then it was deleted on the driver's side and stayed on the passenger's side, to the best of my knowledge. I think there is some info about it in the Tech Manual, it has also been discussed on the forum.
Passengers were tearing off the door pocket until the screw holding upholstery panel to the frame was introduced. Door pull stayed. Drivers were more careful, they did not need the door pull handle.
Post by: MP on February 02, 2022, 11:04:43
Thanks Pawel
Post by: Charles 230SL on February 07, 2022, 20:09:16
I removed the passenger side door panel and was happy to find that the (4) threaded holes for the pull handle are in perfect shape. As noted, the pull handle is attached to the door frame with M4 panhead machine screws.  The photos show the holes in the door frame - note the two screws to the right of the bottom holes. In order for the handle/panel to clear these screws, the bottom mount of the grab handle is raised approx 2 - 3 mm. There's also a small (wood?) reinforcement block with 2 holes to support the bottom of the grab handle - I'm missing this little block of wood and I will need to fabricate one. I know this is a stretch but...would anyone happen to have one of these "reinforcement blocks" readily available, that they can photograph? thanks X 1,000,000, Charles
Post by: Charles 230SL on February 08, 2022, 13:06:44
I used the method recommended by Dale (October 3, 2012) to mark locations for holes in the leather: https://www.sl113.org/forums/index.php?topic=16914.msg119252#msg119252.  I must say that it was a bit unnerving punching through the leather for the screw holes - but all went well.
Post by: Pawel66 on February 08, 2022, 14:47:00
You can kill me, I do not recall anything like that there... I will be where my car is on Friday, door upholstery is removed, I will check, but I do not recall any issues with the screws nor the "elevating piece" there...
Post by: Charles 230SL on February 08, 2022, 19:37:32
ok, thanks Pawel. This is the 'reinforcement block' I'm referring to (picture taken from the Tech Manual)
Post by: Pawel66 on February 08, 2022, 20:41:45
I guess I just have round holes for the screws in upholstery plywood, otherwise you indeed need to equalize the levels so that the pull handle rosette fits the upholstery material. I do not know what was the original solution...
Anyway, if I were to fabricate them, I would use aluminum bar, say 3mm, not wood. I would drill 5-6mm holes, then cut the length to get the rectangular shape. Probably 10min of work each if you have a vice, drill and a simple metal saw.
