W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: steve_barrett1958@att.net on June 08, 2023, 20:13:50
Title: Brake lines fitting size
Post by: steve_barrett1958@att.net on June 08, 2023, 20:13:50
Does anyone know the thread size designation for the fittings (line and bleed) in the brake calipers for 1968 280sl?  I am rebuild and need to pump out old pistons and need to adapt to caliper female fitting port.
Title: Re: Brake lines fitting size
Post by: WRe on June 09, 2023, 08:44:29
is not necessary to build an adapter for it, it is enough to seal the port a little and press very carefully.
But be careful because the pistons shoot out like cannonballs.
...WRe
