W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: sens on February 12, 2024, 21:26:06
I am changing the seals of my power steering pump.
What would be the best way to get the seal out on the shaft with the pully?
From the outside or first get the shaft out?
Do I run into a lot of problems if I try to get the shaft out?
Thanks a lot!!
Halvor
Finally the seal is easy to remove with a screw driver as long as you pay attention not to damage the shaft.
Halvor
