W113 Pagoda SL Group => General Discussion => Topic started by: mauro12 on April 06, 2024, 16:30:54
Hi guys , yesterday I was in my local Mercedes Benz dealer and I saw for sale the genuine Mercedes atf 236.14. I was wondering if it’s a good idea to put in my 5speed zf gearbox or is a too modern version for our cars .
Last time I replaced the oil was 4 years ago with regular atf ( maybe from castrol ). The original service manual says to replace the manual gearbox fluid every 20.000km but doesn’t explain how often if you don’t cover that distance ( I do barely 1000km per year ). What do you think it’s a good idea ?
Same question for the differential oil , in this case is recommended 75w90.
Thank you
Any ideas ?
In the Enthusiast Service Manual, page 5, you will find all the fluid specs. See https://www.sl113.org/wiki/Restricted/ServiceManual
I use a synthetic ATF in my car. For such a rare and valuable item why not use the best you can get.
Genuine Mercedes atf ( probably made by Petronas ) would be ok or maybe too modern ?
ZF recommend a 75w80 ( Ecofluid M ) for the S5-20 gearbox, look on their site and gearbox list and fluids.
An alternative is Pakelo Golden gear LD Plus, similar spec .
That’s strange because Mercedes has always recommended atf
ZF make the box, look at their site.
I'm sure MB would have been using ATF back when the car was new. They would be the ones covering warranty.
I'm not saying don't use it, I was but things move on.
ATF would be worth trying..at least you know it won’t do any harm.
I see the pdf that recommends Ecofluid M also recommends a wide range of other transmission and engine oils for use in the ZF S5-20.
As to whether that specific ATF 236.14 is good for the job Mauro, I don’t know but you can check it’s specifications against those in the pdf and Jowe’s link.
Only 1.1 litre required so yes ‘use the best you can get’.
I was told by a gearbox engineer the ATF gives a good change but does not protect the gears like the 75w80.
HI ; in the mercedes owners manual is written to use atf type a which no longer exist . Some days ago i was in my local mercedes dealer and i was looking at genuine fluids. My question is still the same : Are modern atf (236.15) compatible with the 5speed zf or not ? i've always used regular atf from castrol or motul.
I have Euro spec 4 speed manual, I use
MERCON ATC. The new product is Denton III.
I was thinking if the latest atf from
Mb could improve the shifting , since it is more fluid .
If ZF recommend Ecofluid M 75w80 why would you be looking for an ATF
That’s an interesting topic because is no sense . Zf reccomend one thing and Mercedes another thing . I’ve read too that zf suggest 75/80 , I’m just wondering why .
I guess the shifting with 75/80 is much heavier than atf .
Do Mercedes really still recommend ATF ? Wouldn't they take the advice from ZF who make the gearbox. ATF was recommended originally but time and things move on.
I believe so . Maybe more expert in the forum can clarify this aspect .
Back when I worked in the dealership (40 years ago....) we used ATF 200 in all manual gearboxes. It was a gold colour rather than the red of the ATF 220 we put in autos.
You were working in a Mercedes dealership back 40years ago ?
This is why stick knows so much about our Mercedes Benz cars ! He was trained by Mercedes Benz and has worked on these cars his whole life. His workshop is a wonderful place to visit
Sad but true! ;D
