W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Harry on July 01, 2024, 18:43:38
1966 230SL.
Hello. I am just checking for the availability and source for a camshaft for this car. Are they still available? If so, who is the source(s)?
Harry
Hi Harry,
Do you have the old cam shaft? When I purchased my 1966 230SL it had one lobe that was nearly gone due to not getting any oil from the oil tube. I knew it had a real problem, but I bought it that way.
I sent the cam shaft to a place in Texas I think. They "spray welded" it and then ground it to factory specs. When I got it back, it looked like new. That was 22 years and 60,000 miles ago.
I keep records and receipts of everything I do to my cars. If it will help you, I'll look through my records.
Ed & Clover Riefstahl "Cruising the back roads of America, one mile at a time".
1966 230SL (Ms Magoo) Horizon Blue
1970 280S (Miss Daisy)
1999 BMW Z3 5 speed
1991 BMW 318I 5 Speed
1997 Toyota Paseo Convertible - One of 1000, (have you ever seen one?)
1997 Ford Ranger step side (Mater)
2023 Mazda CX 5
Modify message
Have you checked the usual parts suppliers including the classic center? They likely have them.
https://www.sls-hh-shop.de/main/de/mercedes-230-280sl-w113/03-motor-m127-m129-m130/05-a-zylinderkopf-nockenwelle-ventile
Yes, they are. A 180 051 84 01. Pick up a phone and call Mercedes dealer (or Classic Center in the US). They should be able to help upon providing your VIN or engine number.
Thanks everyone. Good information!
Harry
