W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Paul99 on April 27, 2025, 08:51:11
So (see photo) the points should be closed (ie touching) when cold and ignition off - correct? then should open when cranking etc.
Mine had a large gap when cold. I have adjusted so they JUST touch when cold.. Is that correct? couldn't find the link on the technical manual.
Many thanks
Hello Paul, that's correct, contacts are normally closed, open when cranking after the coil has heated up after one second
Test procedures are on here:
https://www.sl113.org/wiki/Engine/TimeSwitch
Great. Many thanks.
